OTA updates an other errors
  • Thread starter Deleted member 19354
  • Start date
  • Watchers 0
Guest
Today I quickly glanced on my software updates. I noticed I had 5.1.1 which is fairly up to date from what I’ve been reading. However it also said update could not be completed. I called Ford Pass and the software update desk. They took down all my info and said that Ford stopped the update and to wait until they resume. The representative then mentioned I have multiple errors and something about maximum data reached. She was not sure but said I should make an appointment for service. She said some modules are not working but didn’t go into detail.
Another strange thing is when I turn of adaptive cruise control say I set at 60mph with in a few minutes it changes to 70 out of the blue. Did I hit the wrong setting? I also noticed that while in Bkue Cruise it is now ready traffic signs especially on a curve says suggest 50mph for example. That’s pretty cool!
Any reason why I’d have all these errors?
Thanks.
I'd need your VIN to figure out what's going on with your OTAs, but 6.1.0 is still being deployed. But if you can't wait then you should go to your dealer.
You probably have speed sign recognition turned on, which will adjust based speed limit changes. Better turn off that setting.
5.1.1 failed to install and was cancelled by Ford. Looks like it failed because of a manifest mismatch, hard to say why but I would second the advice that you should just go to the dealer and have them apply it manually.
Guest
Sure will. Does it show all of the other errors? Thanks again!
You have some normal trouble codes, those might look scary to someone who doesn't know much about them. The only odd one you have is a trunk lamp circuit open in the past, so not sure if you were doing something and unplugged a light?
Similar threads
Replies
Views
779
2 3 4
Replies
50
Views
6,667
Replies
Views
1,923
Deleted member 16048
