Partial amber light - mobile charger - what does it mean?
LikeAGFeld
Gary
2023 MME Select
What does this mean?
seems to be charging just fine.. doesn’t feel hot…
Any clues?
Ford Mustang Mach-E Partial amber light - mobile charger - what does it mean? IMG_2843
WongWhey
Tony
2023 Ford Mustang Mach-E, 1967 Ford Mustang
Military Musician
So I was using mine fine at one house (first time using it), then drove it to my house and got amber. I’m just moving into this house and going to have electrical work done. I knew most of my outlets had no ground, even if there was a three prong outlet. Sure enough I got a tester, every outlet near my garage is ungrounded. I brought the mobile charger inside to a known grounded outlet and it worked!
areacode413
MA
MachE
Won’t the evse throw a GFCI error without a proper ground to monitor?
Mirak
Kansas
Any clues?
It means it’s on its way out. Replace under warranty if you can.
Womps
Sid
Alberta
2025 Cadillac Optiq and 2026 VW Tiguan
From your Manual.
Ford Mustang Mach-E Partial amber light - mobile charger - what does it mean? IMG_1656
r8humiston
Ron
South Amboy
2021 Mustang Mach E
Thanks. Nothing is flashing. No red.
Tom's Ford in NJ could not even check the charger because they don't have a 220 line for level 2. Who do i contact about getting it looked at.?
Mirak
Kansas
Call Ford, explain your problem, tell them to contact the dealer and tell them that it needs to be replaced. Some dealers suck. Mine replaced it without question.
And be sure to tell Ford their dealership is not properly equipped for testing Ford EV equipment. We're just talking about a 14-50 outlet here, not a DC Fast Charger!
CarGuy11
Pittsburgh
2022 MachE4X Prem, 2020 GRSupra, 2016 Corvette Z51, 2024 Emira
I got just solid Amber light but wasn’t even plugged into car. I unplugged and replugged into receptacle and went away. I suppose in order for dealership to replace the amber light will need to be on?
Ford Mustang Mach-E Partial amber light - mobile charger - what does it mean? IMG_4818 Larg
From the manual for amber light on solid (not flashing):
Ford Mustang Mach-E Partial amber light - mobile charger - what does it mean? IMG_0764
Does this happen all the time or every once and a while?
I get that light once every few months. If I unplug and replug it from the wall it goes away.
In my case, either the charger is warm or it’s likely just a generic fault (maybe a power surge or outage caused it).
But I haven’t replaced because it still works and chargers almost always.
