Phone -- Profile Alignment
pygolpher
Josh
MN
2023 Mach-E Premium
Anyone have a link (or just plain explanation) on how to associate phones to profiles within the MachE? I had turned off walk away because every time I came back and the car saw my phone it thinks that I am my bride that has a quite a bit different profile than I do. I am not seeing any obvious place way to set my phone to line up with the profile on the vehicle.
nicholsjon
Jon
Texas
2023 Mach e ER RWD Premium, 1965 Mustang Fastback, 2019 Subaru Crosstrek
I found that once your phone has Ford Pass and is linked to the car - then you can go into your Profile settings and link the phone to your profile. Once in your Profile - press Edit. Then you'll see a button for Linking a device (or maybe it says link a phone) to the profile. When you select that option - it then tells you to use the Ford Pass App on the phone you want to link, and press the Lock Button. Then that phone should be linked to the Profile you're in. I just did this for my phone, now I need to try it with my wifes phone to her profile - and we'll see if that fixes the constant phone mix ups. It's still too early to say if this works - but at least I was able to link my phone to my profile.
