zealtajpuria
- Zeal
- Jun 16, 2023
- South Elgin, IL 60177
- 2021 Mustang Mach-e First Edition
I am talking about the Ford Connected Charger App. You can pick the AMP from 15 to 48 AMP. If I charge it to 48 AMP then it won't charge but 36, 30 and lower AMP works fine. So I am guessing it is the charge station having the issue not the charger port on the car. I am having this discussion with Ford representative and will update here what they say.I had a charging problem where it would start to charge and trip the breaker after a few minutes. It turned out to be loose connections at the breaker. However when charging it cycles from 31 amps to 15 amps. What app are you talking about where you set the charging rate?
