Power-Up 6.7.0
T.S.
Sue
Valley Forge, PA
2021 Mustang Mach-E
When you turn Auto Updates off, Sync will display a notification when you turn the car on that an update is awaiting your approval via the Update Now button.
That way I know my VIN has come up in the OTA lottery and I can make sure all of the OTA pre-reqs. are good to go. I can not take credit for this trick, I got it from @Logal727.
However, that's not so different than leaving auto update on and getting a notification through FordPass that you received an update...is it? 6 of 1...
Just Lurking
Paul
Washington
2022 Mach-E GT
It's not even necessary. Even with auto-updates on, Sync will prompt to update now (for an inhibit update) or prompt to let you know that an update failed, at which point you can take action to remedy the update failure (which seems to typically be a low 12V battery.)
LinkRS
Rich
Texas
2023 Mustang Mach E GT Performance Edition
This was what I thought? Which is why I am confused about this.
Scorpy2643
Scorpy
Iowa
2021 Mach-E Premium ER AWD, 2018 F350 Platinum
I apparently received 6.2.1 as a shadow update. No notification upon entering the car, no message in my app, nothing. I looked at updates and there it was as “completed”. Watching for more….
21 job 1. Non ea.
Killerkg
Kunal
Vienna VA
2021 Mustang Mach E Job 2
Finance
Just got my 6.2.1 today. Which power up brings bluecruise 1.3 ?
TheVirtualTim
Dearborn, MI
My '23 is up to 6.7.0. My '21 made it to 6.6.0 ... still waiting on 6.7 (and it's a Job-1 car so I'm very interested to see if 6.7.0 does actually enable the Frunk for Job-1 owners.).
I am in the EAP.
TruWrecks
Oregon
Mach-E Star White Premium AWD Ext (Ghost Stallion)
What about bluecruise 1.2, do we get that or it goes from 1 to 1.3
From 1.0 to 1.3, but it won't happen until Dec 2024 because it is Ford.
I am in the EAP.
It does. You should get all but the button on the Sync screen. That requires the next Sync update.
bigredx86
Pittsburgh, PA
2023 Ford Mach-E Premium STD AWD
I’m still sitting at 6.1.0 for my 2023 Mach-E Premium ER. :-(
You probably got the no name power up as we never got notified it installed but we are also still at 6.1 but with 23-PU1103-NAT-VCE. I noticed it no longer said the power up version and when schooling to the bottom it shows VCE.
ebeponyan
Puget Sound
2021 Infinite Blue Mach-E Premium AWD ER
We're expecting FordPass and Keypad functionality even without a BCM update? Presumably we should also be able to run the routine to enable the button in sync if feeling impatient.
