Random climate on/ preparing for departure
EVEE-G
Cisco
2024 MachE GT
RN
Has anyone been having issues lately with climate on or preparing for departure turning on at random. I noticed month and a half ago the app would show me a message saying too many climate on and the car needed to be started to use again. Today at work someone told me my lights were on and I checked the app and climate was on. Seemed to happen when I was plugged in but after today seems to happen regardless. I factory reset and set everything up again a day ago too, since Fordpass app was not communicating with my 24’ MME GT with 10k miles. @Ford Motor Company
Tampamike
Tampa, FL
‘24 Mach E Premium RWD
Do you have any departure times set? Once you set one, it becomes permanent until you delete it. I’ve set them before for specific departures and then forgot about that, only to find out later that it was still there.
EVEE-G
EVEE-G
Cisco
2024 MachE GT
RN
I have and change them often. Once it started doing it I turned them off and it still would happen. Its not at the set times that either when it was set. Just wondered if after last update anyone else had similar issues.
QUOTE="Tampamike, post: 1000355, member: 2861"]
[/QUOTE]
ArmySapper
Lance
Phoenix AZ
2024 Mach E
Electrical Engineer
I've seen that as well. Then I see you too live in Airzona...is your vehicle parked outside? Mine is and I was thinking it was something that happens from time to time to cool down the vehicle? This is 100% me just guessing tho.
EVEE-G
EVEE-G
Cisco
2024 MachE GT
RN
No and I’ve seen when it cools and it stops on its own and its for very short times. Never affected the climate on before. When I say ON, I mean lights are on, getting ready for departure
ArmySapper
Lance
Phoenix AZ
2024 Mach E
Electrical Engineer
Sweet..ok just checking.
I personally don’t use departure times and have seen my vehicle be running and on the app have it say preparing for departure and I was assuming because it was 115 degrees plus and it knew it was plugged in it just did that to cool things down. 🤷‍♂️
