Recall 25S65 OTA Update Rolling Out
67 Stang Convertible
Rich
Georgia, USA
Physician
Do you have all of the driver assist features turned off? Adaptive cruise, lane centering, etc.?
It won't recenter unless all of those are off.
Yes, the only time I put any ADAS on is if I’m on the highway for a trip. Outside of that I want to do the driving. It’s just for whatever reason Ford has decided not to send me the centered speedometer OTA?!?! :(
GrayWolf
Brent
Atlanta, GA area
2021 Mach-E GT (Star White Metallic)
Interestingly, I received this update yesterday.But it called itself PT-25.14.22 - perhaps a different build due to issues found during the rollout? Either way, it's nice to get a recall update OTA vs using a dealership to update the modules.
Dana3502
Dana
Des Moines
2024 Mach-E
Update done. But Ford website still says I have to do the recall. I guess I'll need to visit the dealer ?
I was texting a Ford advisor and he confirmed that my recall was done even though the app still said recall incomplete. He said I needed to enter the service on the website. I did, but I have no faith that my entry will do anything to clear it. It was very generic. All I could do was describe in the comments that I did the OTA for this safety recall.
TheRock
Canada
2024 Mach-E Premium AWD with Extended battery
It s
Where to ?
OrchidMania
Miami Beach
Grabber Blue Premium ER
So my
Update keeps failing due to low battery. 25.24.18 is my build
Mobile service coming out Monday to install. Wonder if I need a new battery.
So my
Is the current 12v more than 36 months old? If so, then yes. Otherwise, go drive it for awhile or turn off the shutdown timer and let it run in the garage (etc) for awhile.
SOSMachE
Stephen
South Florida
2022 Mach E premium AWD ER - Iced Blue Silver Metallic
My car downloaded the 25S65 update yesterday. Overnight, it failed to apply the update saying update interrupted. Assuming low battery, I turned the car on and ran it over two hours in the garage, and then manually started the update. It worked!
My 12V was replaced in May this year and this is the first update which failed due to low battery that I recall.
OrchidMania
Miami Beach
I just drove car for a
50 minutes mostly on I95 the update failed.
don’t have a garage Do I have to leave the key in the car.
SOSMachE
Stephen
South Florida
No, you don't have to leave the key, the car will honk as you walk away with the key. You will have to turn off the "power off after 30 mins" setting in the car, of course. Turn the AC and headlights off. Mach-Lee, in one of his posts, says how long to run the car to charge the 12V adequately; you could try 4+ hours.
  • Like
Reactions: Aza
Aza
DFW
2023 Mach E
I was having the same issue with the update interrupted. I ran mine in my garage for 3 hours. It worked! Update successful!
OrchidMania
Miami Beach
Ford is coming out Monday to do mobile update. Was scheduled before getting OTA requests.
does FDRS need the same battery level??? I assume that’s what they use.
They should have a power supply that they’ll attach to the 12v jump points while doing the update. That will be all that’s needed for the PCM & SOBDMC modules (iirc) that are updated.
Chainspell
Erich
Sacramento, CA
'21 Premium 4X, '23 GTPE
Letting the LVB get charged up also worked for me. The update failed a few times in a row, even the automatic scheduled one at 0200 which should have been after my car finished charging overnight. My LVB was around 75% today when I checked it. I let the car sit turned on and plugged into EVSE for a few hours until LVB reached 85% (disable the auto shutoff timer). The next update attempt (initiated manually) went through no problem and took about 20 min. LVB was at 72% after update finished.
  • Like
Reactions: Aza
OrchidMania
Miami Beach
How do you check your LVB?
