Same service issue keeps popping up
dpappyp
Milwaukee
2021 Ford Mustang Mach E Select Standard Range
Only owned my 2021 for a few months and this already the third time I’ve had this service alert pop up. Dealer just clears it and says nothing is wrong. Any ideas?
Ford Mustang Mach-E Same service issue keeps popping up IMG_7314
Snakebitten
Coastal Texas
2023.5 Mach-E
I would pull the codes associated with the alert. At least you might know what is triggering the generic alarm
dpappyp
Milwaukee
Will a regular obdii reader work on these things?
The P0929 code is caused by turning the gear shift selector without putting your foot on the brake first. There is a SSM for this issue: https://www.macheforum.com/site/thr...ht-with-dtc-p0929-77-stored-in-the-gsm.23309/
In your case, the gear shift module may need to be replaced if the hardware code matches is one of those listed in this TSB: https://www.macheforum.com/site/thr...pressed-transmission-remains-in-park-p.21849/
You also have a USB port that is shorting out sometimes. That could be from plugging in a faulty cable or device, but it could also be a wiring issue. The vehicle has a history with a pinched wire harness behind the dash affecting the gateway module communications and was a buyback.
dpappyp
Milwaukee
Thanks! Yup, I know it’s a buy back, why I got it for $21k after tax credit. I do have a magnetic usb cord plugged in so the contacts are more exposed and could be the cause of the short. The harness issue was supposedly fixed during the buyback process.
