PianoDan0
- Jan 2, 2024
- Pennsylvania, United States
- '21 Mustang Mach-E RWD ER
Hi all, I got the SVS warning early on in my ownership (got the car used in September 2023) of my 2021 Job 1 Premium RWD ER. I kind of freaked out and took it right to the dealer. When the dealer got to working on it, it no longer had any warnings and they took it for a few days to see if they could replicate it and they couldn't. They ended up seeing a few modules needed reprogramming so they did that and sent me along and told me to monitor it and let them know if it happens again. For a while, it never reappeared but I believe I can get it to consistently show up under certain circumstances.
After I drive home from work (which is 50 miles one way), if I turn the car off and let it sit for a few minutes, then go back out to the car and restart it, it almost always pops up. I usually arrive home with about 40-45% SoC left. The SVS, Powertrain Malfunction/Reduced Power, High-Voltage Battery Warning all come up. Usually if I just plug the car in and charge overnight it goes away. I've found that it appears to be related to the P0B24 DTC. That one will always pop up when this happens and one time I cleared it and all warnings went away immediately.
I don't believe it's a HVBJB issue and plus I just got mine replaced about a month ago. I've suspected my 12V battery is having problems because sometimes a whole bunch of errors (Hill start assist warning, cross traffic alert, OPD fault, blind spot warning, service AdvanceTrac, and probably a few other I'm forgetting) will pop up. After a minute or 2 of driving, they'll usually all clear up. I started @Mach-Lee 's process of desulfating the battery this past weekend to see if that helps. I'm on day 3 and the current has dropped to about 50mA so I should be pretty close hopefully.
I also noticed my HVB SoH seems awfully low, at 89.5%. The car has 26k miles on it. Since I've gotten it, I've fast charged maybe 5 times. Most of the time the battery sits between 40-85% and I drive pretty conservatively. That being said, I have no clue how the previous owner drove it. Looking at the CarFax, it's a bit hard to follow but it seems like it was driven something like 18k miles in 7 months which is pretty high, so they could have been fast charging a lot and really pushing the car. I'm wondering if my battery pack is having issues which is throwing the P0B24 error and reporting a lower-than-I'd-expect HVB SoH.
Attached is what the error codes show on this most recent time it's happened, as well as my SoH reading (note the battery is at 10% SoC which is why cell voltages are lower). I must have a very early model to be at 3.5 year old HVB.
Looks like the HVB module variation is 80mV which really doesn't seem that high but maybe high enough to trip a threshold to throw that error, or maybe a bad module?
Any idea what could be going on?
