Setting preferred charge time causes Charge Station to cycle
MetalCord
2024 Mach-E GT AWD
IT Manager
I gave up on the preferred charge time and just plug it in at 9 PM (start of the power charge cost). Tired of the work around. I chalk it up to the beginnings of the new technology.
My power providers EV charge window is from midnight to 8 am. The workaround is not ideal but my commute is so short that if I forget once or twice or three times, I can still forget until the weekend when I'll be up at midnight anyway. ?
stoopid
stoopid
Las Vegas, NV
2024 MME Select, RWD, Standard Range, Ford Charge Station Pro
I had this happen to me when on the first day I brought my Mach-E home. I have an Enphase HCS-40 EVSE that supported my Chevrolet Volt of 10 years with room to grow. I fixed it by:
  1. Delete the preferred charge times from the app and in the center screen.
  2. Turn off walk-up or welcome lighting. (Walking near the car with your keys or phone also causes the EVSE to cycle.)
  3. Set your preferred charge time using the center screen.
In general, use only the center screen to change settings. Use the app only for lock, unlock, remote start, view status, and initiate charging.
I tried this, and it seemed promising as the charger went to a solid yellow(?) light, the car eventually showed no lights at the charge port, and the charge station wasn't cycling like it was before when preferred time/target charge were setup. However, it did not charge overnight on schedule and the app only indicates a generic 'Charging Error'.
I'm going with my gut and leaving this alone for now, until something official from Ford appears/gets pushed to either the app, car, or charge station via software update. Spending any bit of time or emotional energy in hoping this, that or the other works is waste IMHO. There's clearly an issue with how Ford's charge station is being implemented with charging schedules.
thx10
Missouri
2025 Mustang Mach E GT
Last night was my first night with the FCSP. I had it set to start at 2300 No issues but I did notice when I looked at amount of time to charge first thing in morning it didn’t register. Then after I unplugged it, the data seemed to upload and it posted in the app.
I reset the charge time to start at midnight and end 0500. I’ll see how it is in the morning - second day with FCSP and update here
thx10
Missouri
Follow up. It charged at midnight to 1:15. Got it to 90% like i scheduled it for. But this morning when I disconnected charger from port, the light on the FCSP turned solid white or light blue. Waited a few minutes and it didn’t do anything and my app couldn’t reach the server
Killed the breaker, waited about 5 minutes, breaker back on and blue solid lights. My app then could reach/read the FCSP.
I deleted my time to charge and will just plug in before I go to bed
MetalCord
2024 Mach-E GT AWD
IT Manager
I just have the Ford Mobile Charger but never had the issue you are describing. Hope Ford figures it out for you.
Out of interest, if your charger is pulling 48A, what is the size of the circuit breaker?
In the interest of transparency to help discern any other patterns (other than the FCSP being the common denominator), my Ford Charge Station Pro is limited to 48A (via the internal dial) and is hardwired to an 80 amp breaker which is in a 100 amp panel dedicated to my garage.
thx10
Missouri
Mine is also dialed to “5” (48 amp) inside the FCSP and hard wired to a 60 amp breaker in a subpanel that is on a 80amp breaker in main panel. This is the only item and breaker in my subpanel
stoopid
stoopid
Las Vegas, NV
This isn't a power issue, otherwise the charge station would exhibit issues other times it's charging.
Mr Card AMT
Visalia CA
2024 Mach E Select AWD, 2015 Mustang GT, 1956 F100
Aviation Maintenance Instructor
Isn't the car limited to 32A regardless of the setting on the wall box?
My Pro version was installed a week ago, and has only hiccuped on me once - showed a charge fault the next morning, but it was at 90% so it did charge. Since then, the preferred charging time has been functioning as it should. My rate drops at 9pm, but I have it set to start at 10pm. At 10 it starts like it is supposed to.
WEC
West Columbia SC
2025 Mustang Mach E Premium RWD; 2025 F150 Lightning Flash
Chemist
No, the Mach E has a 11.5kVA AC charger which means at 240V it can take 48A of current.
knemchak
Kenny
2023 Mustang Mache GT
Same here. But it's 7pm for me.
MetalCord
2024 Mach-E GT AWD
IT Manager
I'll echo WEC's reponse and confirm that the Mach-e has a 48 amp limit on Level 2 AC charging. I don't know where it started but there are threads all over reddit stating INCORRECTLY that the limit is 32 amps.
WEC
West Columbia SC
Chemist
I will add our vehicle to the ones exhibiting this issue. I may have time to experiment with it this weekend. We also have a 2025 F150 Lightning Flash that I have never set up preferred charging on so I will see if it behaves the same way as well. Hopefully this will be resolved; very surprised this isn't a mature feature; hasn't it been around for some years??
MetalCord
2024 Mach-E GT AWD
IT Manager
It sure has.
Sally_mache
Sally
Brisbane, Qld
Mache GW 2024
This issue has been happening for me for awhile now - I think it started around Feb. Prior to that - I never had an issue with preferred times and it was working as it should every night. I can't keep setting an alarm to get up at midnight to plug it in. Has anyone found a resolution?
tonytaylor53
Southeast
2024 Mach E GT, 1993 Ranger
Not to necro, but the optionally included mobile charger is limited to 32A when using the 240V plug. Obviously, a more capable EVSE allows 48A but this must be how the reddit threads started.
Ford Mustang Mach-E Setting preferred charge time causes Charge Station to cycle 1756215844855-y5
