I watched his video. When he was slowing the car in front turned right, the light was red and his MME accelerated. That indicates the ACC/IACC saw the car move from in front and initiated the acceleration even tho he was approaching a red light. He then hit the brakes to stop and the faults ensued.No one is saying it is, nor does it have to be to be used on surface streets.
It doesn't matter whether it did or it didn't, because it shouldn't. Using the brake pedal to disengage ACC is normal functionality on every car on the planet.I watched his video. When he was slowing the car in front turned right, the light was red and his MME accelerated. That indicates the ACC/IACC saw the car move from in front and initiated the acceleration even tho he was approaching a red light. He then hit the brakes to stop and the faults ensued.
Did his braking during ACC/IACC acceleration cause the faults ?‍
That's very true. Was he actively braking or using the cruise to brake for him? He said he hit the brakes as it accelerated. Anyway, just my observation. Don't want to argue, I wasn't thereIt doesn't matter whether it did or it didn't, because it shouldn't. Using the brake pedal to disengage ACC is normal functionality on every car on the planet.
Are you saying in one of those scenarios the car should stop working? Because otherwise I'm not sure what your point is.Was he actively braking or using the cruise to brake for him?
when you say you quickly hit it off, did you use the brake pedal or the ACC button?I quickly hit it off and then bam. Car comes to an abrupt stop.
Hit the CC button if I remember correctly. And I use 1 pedal so I would have applied the brake as soon as I did that.when you say you quickly hit it off, did you use the brake pedal or the ACC button?
In addition to either of the above, do you have one pedal driving enabled when not using ACC?
I agree that the issue should never happen, I’m just trying to determine the steps the car went through to get into such a crappy state.
like, it went to disable ACC and immediately started trying to one pedal stop after it was just thinking it should be accelerating and hit some fault loop… or if you killed it with the physical brake… which I would think it’d understand better.
so you hit the brake or you use 1 petal so “it”would have applied the brake?Hit the CC button if I remember correctly. And I use 1 pedal so I would have applied the brake as soon as I did that.
I use one pedal. I don't think I touched the brake pedal at all. I try to not use it as much as possible.so you hit the brake or you use 1 petal so “it”would have applied the brake?
In any case, glad you’re ok, it definitely should not happen… Ford needs to fix whatever it is if they haven’t already.
I'm saying that would explain why the car accelerated, that's all. The car did not/can not see the red light.Are you saying in one of those scenarios the car should stop working? Because otherwise I'm not sure what your point is.
was your car “Built On Or Before 11-May-2021”I use one pedal. I don't think I touched the brake pedal at all. I try to not use it as much as possible.
If your vehicle wasn’t built before then I’m willing to bet Ford engineers need to take a look at how the vehicle transitions into one pedal driving mode when leaving ACC.TSB 21-2171 strikes again!
Then turning off the CC would bring the car to a stop, but maybe not in time for the crosswalk. If you stepped on the brake, the fact that the car died means it suffered a malfunction.I use one pedal. I don't think I touched the brake pedal at all. I try to not use it as much as possible.
The nut loose between the steering wheel and the drivers seat is the interface for traffic control devices.That is true, but show me were ACC is compatible with traffic control lights?
