Speedo shows 1 MPH while Parked
DevSecNetOps, General PITA
It's a bug, it's fixed by putting a car in the middle where the 1 used to be. Then you forget about the 1kph because you're fixated on the car in the middle of the screen doing nothing.
Come on 7.0 Powerups. There's a growing list of bugs Ford.
McSquashy
Josh
Massachusetts
Mine caught the 1 MPH bug. First time noticing it. Currently on 6.14.0
Ford Mustang Mach-E Speedo shows 1 MPH while Parked 1000005634
Teslaeata
Nottingham, England, UK
Anyone else see this before? Speedo is showing 1 mph but car is parked.
No, but don’t all Mustangs look like they’re doing 100mph while standing still?
Shepherd
Shepherd
Undisclosed
2023 GT
Retired by doge
This one happened to my GT yesterday after 24-PU0105-CMR-FX driver monitoring system for false eyes off warnings.
Driver31x
Saskatchewan
22 Mach-E Premium
Yes, I started to have the same issue with mine over the last while. Sometimes repeatedly. Dealer had a look but not able to find anything.
Dealer was able to resolve issue. They found a DTC for one pedal fault. Ford advised dealer that the ABS module was main driver and to hardwire update(not OTA) via FDRS the PCM, ABS, BECM, SOBDM, SOBDMB, SOBDMC modules and the issue has been corrected.
sukhoi_584th
United States
2022 MME CR1 AWD
Now I've started to get a fake nav alert on the left side of the dash that stays at 1 mi to destination. It went away when I started a new nav in Gmaps but came back again today.
Ford Motor Company
Official Ford Account
Hey there! I can take a closer look into your speedometer concerns should you need further assistance. Please send us a direct message with your VIN and the dealership name/location and I'd be happy to assist. To send a direct message, just click on our username and select "Send Direct Message".
Kabish
2021 Mach-E Mustang
I mean it could be worse :D
This was my car when I first got it, only did this once, never had the issue again. I think it had something to do with a OTA update.
AliRafiee
Ali
Seattle WA
2022 Mach E GT - Grabber Blue
Software Eng.
what’s even more trippy is that when I went to Canada last weekend, I switched to Km/H with the switch in the General settings. It shows Km/H and MPH at the bottom. A couple of times at a stop light it was 0 Km/h and 1 MPH. ?
It hasn’t bothered me in the past year or so that it’s been happening.
treehouse
Tri
Atlantic City, NJ
2023 Ford Mach-E GT
I posted a few days ago it started showing 1 mph after a software update. It corrected itself while i was using the Ford Navigation/map app. More specifically, i had it route me “Home”. While on route, the first stop at a traffic light showed 0 at a stop for the first time in 4 days. Was it coincidental or is this the fix? Try it and let me know if this worked for anyone else.
danielcb
Daniel
British Columbia
Mustang Mach-E 2022 ER AWD
I took my car to the dealership to fix a Failed Software update on the Gateway Module and also complained about that. They mentioned this was a know issue. IPC and a bunch of other modules were updated, but the error is still there.
@Ford Motor Company Can you please provide a definitive solution to this issue? It's been ongoing for months...
I'm not asking for that speed to be 100% accurate to GPS level, but it's extremely annoying that it says I'm still moving, while parked or stopped at traffic light.
I also noticed that the speed information I get from OBDII is slightly bellow or above by a few km/h than what the IPC is showing to me. That also makes me worry I might get in trouble because the information being displayed to me while driving is actually incorrect.
sukhoi_584th
United States
2022 MME CR1 AWD
It is better than the Citroen I was driving in France this summer that shut off while driving. The dash froze while I was entering a construction zone, so I had no idea if I had slowed down enough. After maybe 10 secs the entire dash and HVAC shut off but the engine kept running. It then rebooted and was fine for two weeks after. :crackup:
ChehRob
Rob
Seattle WA
ret
I've mentioned before, some math series begin at zero, some others at one. Who knows what Ford software does, there are likely dozens of programs affecting the display.
