Steering Wheel Accessory Switch Replacement
BenW1976
Rhome, TX
2021 Mustang Mach-E RWD Premium
Has anyone replaced any of their steering wheel switches? I ordered the part just needed directions on how to replace it.
AliRafiee
Ali
Seattle WA
2022 Mach E GT - Grabber Blue
Software Eng.
This is my guess based on changing the steering wheel on a Mustang.
You need to take the airbag off and then pop out the buttons.
Let me see if I can find the instructions on how to get the airbag off.
AliRafiee
Ali
Seattle WA
Software Eng.
I didn’t see instructions on removing the steering wheel shroud. But there are two screws on the bottom part. Then take the bottom shroud off. Turn the wheel to the 6 o’clock to pop out the tab for the airbag. Then turn to 12 o’clock for the second tab.
Ford Mustang Mach-E Steering Wheel Accessory Switch Replacement IMG_0112
Ford Mustang Mach-E Steering Wheel Accessory Switch Replacement IMG_0113
Ford Mustang Mach-E Steering Wheel Accessory Switch Replacement IMG_0115
Basically what Ali said above but you don't need to remove any screws on the bottom of the steering wheel shroud. The top part of the shroud just lifts up. Grab ahold of the top section that has the forward facing cameras and pull straight up.
