Target Charge Level for Single Session
WPJoe
Acura RDX
I have not been able to figure out a way to set a target Charge Level when I'm charging away from home, away from my set Preferred Location.
Can this be done on a one off basis?
No, it cannot.
The workaround is to charge for a few minutes, then disconnect. The location should then show up and you can assign settings to it.
When the Lightning came out last year, it included the ability to make a one-time charge setting that applies to the next session. I’d hoped it would get rolled out to the Mach-E, but so far, it hasn’t.
I haven't even had to disconnect to do this. The location shows up after plugging in, and the settings you assign to it will apply to the current charging session.
WPJoe
Acura RDX
This worked perfectly.
Thank you all for the guidance
Yeah global charge limit is still AWOL…
