Mark813
How does parking on the right end use only 1 charger?
I see what you mean but where I've charged there's no extra parking spot like that, it's a spot for each charger. Thanks for explaining.
That's too bad, some of my Tesla spots have the option to come from the other sideI see what you mean but where I've charged there's no extra parking spot like that, it's a spot for each charger. Thanks for explaining.
Okay so the handicap available spot is your best spot in this lotI see what you mean but where I've charged there's no extra parking spot like that, it's a spot for each charger. Thanks for explaining.
Probably wont be a decrease for Mach E owners.To say nothing of the huge decrease in charge speed
Yup! That’s the spot I always hope is available when I goOkay so the handicap available spot is your best spot in this lot
Spot to the left of the hashes is where the teslas back in
You'll be parked on the hashes like I do regularly.
I need to get a better picture, I actually come diagonal across the Tesla spot to the left of the hashes and only my front right wheel/nose is in the hashes
Unfortunately that only gives you one possible spot where you wouldn't take up two in this lot
I usually check the Tesla app on the way to see how many are charging there and if it's like two of eight I take a chance my spot is open. If it is four or five or more active charging the odds drop but there's two new V4 Tesla stations with long cables - one 10 minutes north and one 10 minutes south. But I have 2 chances out of 8 spots I can use solo, you've got 1 in 12?Yup! That’s the spot I always hope is available when I go![]()
Looking at that cable, I'm betting that it's minimum bending radius will not permit that, and you wouldn't want to ruin that expensive item. At least it would be worth checking out the MBR before forcing it in.It’ll go in that frunk that is sitting empty most the time.
