Tesla SC app
bigdave21956
Yukon, Oklahoma
2025 Mach E Rally
I tried to charge a Tesla SC station this weekend without any luck. Do I need to have the Tesla app if so which one to select the station I was plugged into to initiate the charge? I was using the A2Z adapter and it was in the lock position.
Jeff-NoVA
Jeff
Northern VA
2022 Mustang Mach-E Premium
UnforAll
northern Virginia
'21 Mach-E 4x Premium IB; '24 Subaru Crosstrek Sport
Grad Student
If you use the Tesla app no vehicle update is needed to charge. If you have Priority Update 24-PU0119-DC-CHG4 and the Tesla certificate enabled then you can use Plug & Charge.
Not sure where you attempted to charge, but from what I can see there aren't many compatible Tesla Superchargers in Oklahoma -- one site in Oklahoma City and one site in Tusla.
You can use this link, or the Tesla app, to find compatible Superchargers: https://www.tesla.com/findus?v=2&bounds=35.382028667900165,-80.88826121875,33.10273422092158,-86.02986278125&zoom=9&filters=nacs
Patrick over at @Mach-E VLOG has a great video on this topic:
As @Jeff-NoVA said above, there are many other blogs on this topic in the forum.
Good luck!
Likely incompatible location.
What was the precise location of the Tesla SC Station?
Jeff-NoVA
Jeff
Northern VA
Were you getting charging station error/red ring on charge port light? The adapter can be tricky - even if it seems "locked" it may not be fully on the Tesla plug. Did you give it a good bit of pressure before engaging the lock?
bigdave21956
bigdave21956
Yukon, Oklahoma
2025 Mach E Rally
I'll give that a try see if it works better the next time.
Mike Miller
Long Beach, CA
2023 MachE
We just had a weekend trip to La Quinta in Palm Springs. They had 12 Tesla chargers with adapters for other EVs, including the MachE. We got all the way through the process until a popup said "Try back later. System not working", or something to that effect. We did try back later...and later...and never worked. Then, a young man from the bell staff came down to the garage, took my phone, and after poking buttons for a few minutes, got it to work. When I aksed him what he did, he said it was really complicated and he virtually had to do it for every guest that tried to charge with a non-Tesla. Just sayin'--sounds like Tesla wants to say they offer charging and then make the "Mother, may I?" extremely difficult.
