Don_23805
- Don
- Feb 14, 2021
- Central VA
- Honda Ridgeline, Prem MME DMG AWD Ex Batt
Much ado has been made recently about Ford (& others) buying into a gadget that will let J1772 vehicles use Tesla charging stations. Seems far off; only 10 in NY and 10 in CA. Sounds like an adapter on a Tesla charging cable that would use or release based on what your Tesla charging account said you owned. But on Amazon I see a slew of Tesla to J1779 adapters from $40 to $150. Do these work? Do they only do level 2 charging (which might do in a pinch if you have a lengthy dinner at Wawa)? Do all/some Tesla chargers employ DCFC (or whatever Tesla might call that concept)? What's the catch?
And . . . while charging at home, I tried to get info from the car about charging rate from the Charging screen. Typically Ford Useless; only shows % charge and expected full charge time. Was hoping to get actual info on charging rate in kW or amps from car. Nada. My 240 charging typically charges at about 7.5 kW (60 amps house circuit).
TIA
Don (Central VA)
TIA
Don (Central VA)
