TeslaTap mini 60 amp
River Rat
Britt, Ontario, Canada
22 Mustang Mach Ex Iced Bue, 23 Lightning Ext SW
Only n Canada do we get ripped off on imports. Wonder if these are available from a Canadian dealer there is one in Kitchener, ON?
JohnnyForensic
VA, US
Digital Forensics
Small warning, the TeslaTap people had a website breach of some kind where the attackers have gained access to AT LEAST their customer service question submission data and email addresses, because I’ve been getting hella phishing/credit card attempts with the text I sent in a question to them once from dozens of different email addresses, different wording on the phishing templates, etc. I called and let them know, but it wouldn’t surprise me if they had more.
Northofnine
Northofnine
Innisfil Ontario
Mustang Mach E AWD ext Premium 2021 Job 1 non EA
My Update:
I eventually received my Tesla Tap mini 60amp...it got lost within USPS.
I have actually used it twice since it arrived. Happy to have it.
Took some time to find the proper padlock. ended up with a 5mm thick, that was still a bit tight...I ended up using a drill bit on the adapter to open the hole up a bit.
The Tesla charger fits very tight into the adapter. The recommended grease helped.
Ford Mustang Mach-E TeslaTap mini 60 amp IMG_0243
Ford Mustang Mach-E TeslaTap mini 60 amp IMG_0244
Good to know, I chose not to buy from them after seeing how amateurish their website is (they use a template someone else designed). I don't think the person running the website is very tech savvy, so it wouldn't surprise me if they haven't kept up with critical security updates. They probably had no idea there was a breach, and may lack the knowledge to fix it.
I think they have a good product, but they need to hire a pro webmaster.
ridgebackpilot
Northern California
2022 MME GTPE; 2022 MME Premium ER
Attorney
I bought my TeslaTap Mini 60-amp adapter from Evanex, which is far more secure than the TeslaTap website itself. I use it all the time at home, since I already had a Tesla Wall Charger installed in my garage. The adapter is a tight fit but is well-engineered and works perfectly.
Unlike Teslas, the MME doesn't automatically lock the plug in, so a small padlock is necessary if you want to secure the charging cable to the car.
Anyone that has regular access to a Tesla Wall Charger (commonly used by hotels and other venues as Destination Chargers) should consider the TeslaTap adapter. But remember to buy a 60-amp model; the 40-amp model can't be used safely for continuous charging at 40 amps and higher.
Ford Mustang Mach-E TeslaTap mini 60 amp Tesla Tap Mini
Ford Mustang Mach-E TeslaTap mini 60 amp Tesla Tap Charger
Northofnine
Northofnine
Innisfil Ontario
Have you had any luck getting the other padlock in?
Once the Tesla charger plug is inserted into the adapter, the hole is not totally visible.
So far I have not been able to!
ridgebackpilot
Northern California
Attorney
I haven't tried that lock. My main concern is preventing theft of the $250 adapter, which the single lock on top will do.
GA dream car
Jamison
Atlanta, GA
Rapid Red Premium AWD Extended Range
Biotechnology
My Update:
what grease is recommended? Thanks ?
I was concerned about their security also. The website as you noted is not professional. In addition, I got phishing emails even when emailing directly with the owner, which he promptly denied was an issue on his end. I used a credit card that adds up to 2 years of warranty, and will be watching it for issues, but specifically used PayPal to pay for that very reason.
