TPMS WON'T SYNC
McSquashy
Josh
Massachusetts
TL;DR: My TPMS sensors no longer auto-sync with the car and I'm not sure why.
Background: Shortly after getting my Mach-E in 2024, I bought a new set of GTPE wheels that came with OEM TPMS sensors. I had the tires and sensors mounted, installed the wheels, and the sensors synced automatically with the car almost immediately. No issues.
About a year later, I started getting an intermittent TPMS fault on the driver's-side rear tire. At first it only happened occasionally, but eventually it became a daily occurrence. Around the same time, I picked up a nail and developed a slow leak in that tire. I don't think the two issues are related, but thought it was worth mentioning.
Late last summer, I bought a new set of Rally wheels from Ford, which also came with TPMS sensors, along with a set of CC2s for the winter months. After swapping the GTPE wheels for the Rallys, I was still getting the TPMS fault. I tried using the TPMS learning tool that came with the sensors, but I couldn't get that one corner to sync.
I eventually made a service appointment, and the technician was able to get all four sensors synced. Problem solved... Or so I thought.
After a period with no issues, the TPMS faults returned. This time it wasn't just the driver's-side rear—it started happening on other corners as well, but mostly the driver's rear. Like before, it was intermittent at first, then gradually became a daily occurrence.
Now for the really weird part: I recently swapped back to my GTPE wheels, which previously synced automatically without any trouble, but now they won't sync. Every day I get a fault indicating that none TPMS sensors are being detected.
Has anyone experienced something similar or have any ideas what might be causing this? I'm wondering if it's worth trying the TPMS learning tool again, or if there could be something else going on with the vehicle itself.
Edit: Clarification
Do you have any type of aftermarket electronic equipment installed in the car, such as dashcams, radar detectors, etc.? They can sometimes produce radio frequency (RF) interference that blocks the TPMS signals. If so, try disconnecting the power supply for these devices and see if that fixes it.
McSquashy
McSquashy
Josh
Massachusetts
Thanks for the reply. The only aftermarket electronic accessory that I currently have installed, and has been installed for a while, is the FitCamX. Oh, and I guess the Twaps dual phone charger tray.
Edit: Oh, wait, I also just installed aftermarket LED rear side markers.
Say I unplug these item and the sensors still don't sync. What would be the next step in diagnosing the issue?
FYI FitCamX is known to cause TPMS interference. They have a noisy power supply.
Next step would be to remove/disable all the aftermarket stuff and bring it to a dealer for diagnosis.
McSquashy
McSquashy
Josh
Massachusetts
Ok, thanks 🙏
This is the first I'm hearing about FitCamX potential causing issues.
McSquashy
McSquashy
Josh
Massachusetts
Quick Update -
Over the past several days, I've noticed that my TPMS appears to sync when the car is parked at home near my winter set of Rally wheels and tires. However, like clockwork, every day at the same location on my commute to and from work, I get a TPMS fault and none of the sensors are detected.
Once the fault occurs, the TPMS won't sync again no matter how many miles I drive. The only time it starts working again is when I'm back home.
This seems to suggest that the TPMS sensors in the Rally wheels are still somehow linked to the car and are reconnecting each evening when the vehicle is parked nearby.
To test my theory, I broke out the TPMS learning tool while away from the Rally wheels and wasn't able to sync a single corner. :unsure:
I suppose the next logical step is to schedule a service appointment, but my dealer is over an hour away and it's difficult for me to get there during business hours. I'd much rather solve this mystery myself if possible.
Any ideas?
rugedraw
Javier
Miami, FL
Auto Sales
You would try the TPMS calibration with FORScan. I've never had to do it, but I swear I have seen that function in the service procedures. I googled it and it says FORScan can do it.
McSquashy
McSquashy
Josh
Massachusetts
I'll definitely have to look into it.
I never had a issue with the car auto syncing TMPS until after I brought it to the dealer last winter. I wonder if there's a setting in FORScan or FDRS to toggle TPMS auto learning off or on?
rugedraw
Javier
Miami, FL
Auto Sales
Yes, it's in the BCM:
Ford Mustang Mach-E TPMS WON'T SYNC 1781200119603-nv
Edit: Not sure if FDRS can do it.
Supposedly, TPMS sensors need to be rotating to work, so the pile of tires should not connect.
rugedraw
Javier
Miami, FL
Auto Sales
Are these settings are accessible in FORScan?
Yes indeed. I just pulled the config from a random 2023 Mach E and it shows an E there. So if all you want to do is disable autolearn, then that value needs to be changed to a A.
My question is why aren't the current set of wheels autoleaning or training? They should. I switch wheels every spring and fall, and keep the unused set right next to the Mach-E in the garage like you. It automatically figures it out, and I never have to train sensors.
I park at work and take trips, and there are never any warnings after I've been parked away from home.
If you can't train your current set of wheels with the TPMS tool (parked away from the other set), then I'd say you have the wrong TPMS sensors in your wheels. My guess is if you got newer GTPE or Rally wheels, they came with the 433 MHz sensors, and your car takes 315 MHz sensors (Ford switched the TPMS frequency in 2024, I believe). So most likely, you'll need to swap out the TPMS sensors with the correct versions for your model year.
Schrader 20452 are the 315 MHz sensors if you need to buy some.
McSquashy
McSquashy
Josh
Massachusetts
While I understand what you're saying, all of the sensors in both sets of wheels (GTPE and Rally) have been sync'd to the car at one point.
Please correct me if I'm completely off base, but is it possible that the dealer switched off TPMS auto learn and now my Mach-E is permanently linked to the set of sensors in my Rally wheels?
That's the only thing that would make sense to me from what I'm experiencing.
I would very highly doubt they would do that, because it requires 3rd party software (FORScan) and the knowledge of how to do it. Dealers don't use FORScan or switch on or off config options; they use FDRS, which doesn't typically allow those sort of config changes. FDRS would just have a train TPMS sensors option.
If the exact same sensor was known good previously, then they should be on the right frequency, but I'm not sure if someone swapped or replaced sensors at some point? You said you had a slow leak on one tire, which would kill the sensor battery due to constant low pressure alerts being transmitted. If you injected tire slime, that would also condemn that sensor and force a replacement.
I really think the issue is with the RF layer here. Either the sensors aren't transmitting when they should (while in motion), you have sensors on the wrong frequency, or there is too much RF interference.
Since you said you cannot manually train some sensors (assuming you are doing the procedure correctly), I would suggest you call around and find a tire shop that has a TPMS service tool that can read the sensors and battery status. The shop can trigger and read each of your four sensors to verify they are transmitting good data and the battery isn't low. It's possible you have a dead or bad sensor in one or more wheels of your current set. Once you verify all the sensors are good, then I would move on to worrying about the BCM configuration or hardware being bad.
