Upgraded Brake Rotors?
claytionthecreation
23 MachE GT
Well we are all in good company lol. Ford now reminds me a lot of GM before the big bankruptcy…not that they are going bankrupt but they are going backwards with quality control and customer service.
I am curious to see how the OP fares with different rotors. I always like seeing how people mod their vehicles or how the aftermarket address mod and equipment.
CarGuyBill
Georgia
2025 Mach e GT Performance Upgrade - 2025 Ford Bronco Badlands Hoss 3.0
Photographer
Approximate price?
Total with GA Tax $228.80 and after washing the car twice the rotors do not rust! Great improvement.
CarGuyBill
Georgia
Photographer
I would double-check those parts. The GT and GTPE have different size rotors.
The only rotor I have seen besides the motorcraft part is Raybestos Element 3. Hopefully, those DF are correct I won't buy drilled or slotted rotors for cars that did not come that way stock. When you reduce the friction area you reduce the stopping power.
For GTPE
https://www.raybestos.com/disc-brake-rotor-682859fzn.html
For GT, Select, Premium, & CR1
https://www.raybestos.com/disc-brake-rotor-682744fzn.html
They went back and forth and supplied the correct rotors for the GTPE but they are not drilled just flat but work great and do not rust with the coating on them.
CarGuyBill
Georgia
Photographer
I ordered them from https://www.buybrakes.com/2022-ford-mustang-mach-e/brake-rotors They could not supply the Drilled and Slotted but could do the coating on plain rotors. The photos are after washing the car and no rust!. I have just over 800 miles on them. The measured exactly the same as the OEM and pads were identical even the hardware kit.
The coating will eventually be worn through, whereupon the rotors will rust again. ?‍♂?
Good to hear that you took care of the warpage problem. ??
CarGuyBill
Georgia
Photographer
I am hopeful it is like the treatment a Glock gets and will not rust. You can take a Glock Barrel or slide and polish it and it will still not rust. Yes the Stopping is I would say better then new.
claytionthecreation
23 MachE GT
Interesting about the coating. Looks like a pretty cool website. I’d love to hear how they hold up with rain and wear. Seems like their prices are good too.
tuminatr
Saint Paul,MN
2021 MME GTPE
sales
I can't speak to the rotors he bought but I have put those raybestos element 3 coated rotors on a few of my previous vehicles. Here in Minnesota they protect from the elements for about 3/4 years depending on how many miles you drive. They are a bargain if you get them from rock auto just under $62 each rotor
Kirch
Brandon
United States
2021 Mustang Mach e first edition AWD Ex Bat
Military
My GTPE has almost 13k miles and the front rotors are warped to hell. I always used 1 pedal driving. My one pedal stopped working due to a faulty wheel speed sensor so I had to use the regular brakes. The wheel pulses so bad when braking. Is there any upgraded rotors from anywhere yet for these?
Did you ever get any answerers. on your car? I went through 3 sets of rotors in 2 months and now are just dealling with warped rotors... they claim driving habbits but i have never had this issues with any other car.... I am lookin into stronger rotors but im convided the one pedal drive system or the brakes are causing the issue...
that_macheguy
that_macheguy
BRAYDEN
NORTH DAKOTA
2024 MUSTANG MACH E GT PERFORMANCE
Nope. Bullcrap. I traded it with 36,000 miles. Had three sets in that time. I got a 2024 GT now and same shit. Need new ones in 2,000 miles already.never used one pedal in this one and it still does it. I’m so over it.
The car weights 5000 lbs. If you drive it like a 911, it's going to warp the rotors. 100-0 one time will overheat the brakes. A single hard track lap can even overheat the brakes. Keep that in mind or you will have to replace them often. It's not a sports car.
buzznwood
california
focus st & GTPE
While a large portion of the breaking will come from regen when possible, IMO the vehicle is under braked, yes it will stop so it not dangerous but it doesn't take long for them to get toasty when not using regen, which makes the unbridled extended mode even more pointless as it quickly shows up the braking deficiency.
I certainly understand Ford wanting to keep the MSRP down, but they should at least offer a proper two piece rotor 6 & 4 piston caliper option for the GT/GTPE in the ford performance parts catalogue as a retro fit. Even if it is just using the dark horse setup adapted to the mach-e for those of us that would prefer the braking set up on a 5000lb bus to be a bit more than adequate out of the box.
that_macheguy
that_macheguy
BRAYDEN
NORTH DAKOTA
I know how brakes work. I’ve driven many cars with smaller brakes that don’t warp this bad. It’s insane. It’s been nothing but ice since I’ve gotten mine. Absolutely no hard braking whatsoever. Shouldn’t need new rotors every few thousand miles. Even my dealer says it’s garbage. They have had a few brought it for this same reason. Shitty enough that ford even agrees to buy them back with this issue. So no, it’s not my driving style in this case. Furthermore, the GT is literally a Ford performance vehicle, the seats even state that. This car is not to be driven like a grandmas whip. The fact that you just said this is not a sport car is hilarious. So not sure why you are coming up with excuses as to why they have subpar brakes…. This is a performance vehicle, if it wasn’t, they wouldn’t offer things like PERFORMANCE UPGRADE or BREMBO in the first place…
