USB/12v Outlet Timer | Forscan
FrankieD
Frankie
Atlanta, GA
2023 Mach-E GTPE
Hey all,
Does anyone know if you can adjust or even disable the timer for the rear USB and 12v outlets when turning off the car with FORScan?
I would like to set it to turn off with the car, or at least within a minute or so, instead of the 15+ mins that it is currently set to.
Thanks
Hey all,
Thanks
I did answer your question over in the FORScan thread.
Yes you can adjust the time out (I have mine set to 60 seconds) for the 12V power points however I've never checked if it affects the USB outlets. You can disable the time out feature for the 12V power points but all that does is keep them on all the time.
