- Dan
- May 11, 2020
- santa fe,nm
- Website
- www.envirokarma.org
- Solar Sales/install
Looks like a2zevshop carries a range of adaptors and ports.... and now a V2L they say will export up to 20amps from CCS port.
https://a2zevshop.com/collections/charging-adapters/products/v2l-j1772
[update 3/7/24] - I got a call from CEO... the V2L adaptor is NOT compatible with Ford Mach-e or Lighting.
so... if you want to export power.... it's going to be 'roll your own' export from the 12v connection points, or tapping into 400v at Heater connector, to an external inverter
================= moot =====================
The verbage says 120v or 240v, but the picture shows a 120v outlet, and no detailed specs on quality of output regarding frequency, THD, etc. If it turns out to be 20amps- 120/240 split phase, I'm very interested. However, if its 20amp-120v, i'm interested at $90, but only if its pure-sine, and good quality power.
Has anybody gotten one?
got spec sheet?
Tested output?
pure-sine, or modified-sine ?
got spec sheet?
Tested output?
