Walk away lock
FLmac
McKenna
Lakeland, FL
21 premium AWD SR space white
RV Sales
I tried to search but didn’t find anything. My walk away lock and welcome lights haven’t been working for the last 2 weeks. I guess I’ve been lucky because they’ve worked pretty consistently since I got the car. Now neither has worked at all in the last 2 weeks. Any advice other than taking it in?
EELinneman
Eric
Littleton, CO
Sr. Dir Cloud & Projects
Double check that it is not disabled. Settings -> Vehicle -> Walk Away Lock from the main screen.
heisnuts
Darrel
Model 3 Performance
I would try to toggle it off and then back on again in the display. I would also make sure there is not a key (or PAAK) sitting in the car since that would also prevent it from locking as you walk away.
FLmac
FLmac
McKenna
Lakeland, FL
RV Sales
FLmac
FLmac
McKenna
Lakeland, FL
RV Sales
I tried to turn it off then back on. I do have a key in foil in the car. That’s a thought. Maybe I didn’t reward it well enough when I used it about 3 weeks ago. Thanks!!! Let’s see if that’s it.
Socalsp3
CA
Ioniq 5, Mach E
check your phone. maybe bluetooth is off or restart fordpass or phone
FLmac
FLmac
McKenna
Lakeland, FL
RV Sales
The key was exactly the issue! It sounds dumb but thank you so much! This has been driving me crazy! First world problems.
Graction
Gil
Northern NJ
Rapid Red Mach-e GT
I am annoyed by the walk away lock because it only works for me using PAAK like 80% of the time. So I always have to wait and watch to make sure it locks or use the app to force it to lock.
Reactions: x19
Any chance you have a fob in the car in a faraday bag? Mine started doing that and I discovered the cheap arsed bags were only good for a few months. I switched to a small metal box. Foil works as well. All back to normal for me now.
FLmac
FLmac
McKenna
Lakeland, FL
RV Sales
That’s exactly what it was. I use foil and had reused the same piece a few times. I think it just wasn’t working as well. Thanks!
WNKent
Kent
Santa Clara, CA
MME CR1 4X
Airline
So, if the foil wrapping didn't work on a key fob, I'm guessing tin foil hats don't work either; debunked! ?
FLmac
FLmac
McKenna
Lakeland, FL
RV Sales
Lol. It’s worked for months but I have removed the key and reused the foil at least twice in that time. I don’t know if I missed a corner or something or if the foil doesn’t lock the signal or whatever after it’s been crinkled up and reused over months. I’ll just stop being cheap and use a new piece of foil for the rare occasions I need to use the key.
ProfitOfTruth
Jay
Lilburn, GA
2021 Mach-E, 2006 Mustang GT, 2018 Buick Regal GS
IT Guru
So you guys are leaving a fob, in foil, in your car at all times?
Can I get your address please? :cool:
FLmac
FLmac
McKenna
Lakeland, FL
RV Sales
I did it because I had a service appointment then about 3 weeks later I had a flat tire. I also worry if PAAK doesn’t work. Car is locked and key is hidden.
