WeatherTech Floor Liners for MME
We believe the Interior Protection Package contains the cargo area mat but no one has received their car yet to know.
I think that's a pretty good assumption based on the description when you add the Interior Protection Package to an MME order. If it doesn't end up including the cargo mat, Ford will have some explaining to do.
Ford Mustang Mach-E WeatherTech Floor Liners for MME 1610214921784
What do the bottom of the mats look like?
They actually have little spikes all over the reverse side of the mats to prevent slipping, which I'm happy to see. Weathertech mats are just smooth on the back, which isn't usually a problem on the driver's side with retaining clips, but can be an issue in other locations. In my son's Subaru, the passenger side Weathertech mat would slide all over the place, so we replaced it with a Husky mat that has spikes.
I'm really happy with the material, quality, and coverage of these MME OEM mats. This will be the first car I can remember that I don't have to get aftermarket all-weather mats.
Paulalex01
Paul
Sanford, NC
1999 F-150, 2019 Miata, 2009 Element
Retired - Electrical Engineer
It is listed in the ordering guide as being part of package 17P. See attached. This was back in June but nothing has change to my knowledge.
Ford Mustang Mach-E WeatherTech Floor Liners for MME Screen Shot 2021-01-09 at 1.33.45 PM
methorian
Roanoke, VA
IT Admin
It's also listed on your window sticker if you have the package, indicating both cargo protector and front/rear floor mats.
I agree with all of these statements. However, we have seen descriptions of these things change through time. We will know for sure once they start to be delivered.
Metv707
Canada
Ford Mach E
Ford Mustang Mach-E WeatherTech Floor Liners for MME 1610290335289
A member posted this pic a few days ago. Not sure how I feel about that back liner being two pieces. ?
I think it will be fine. With the spikes on the back, it will stay in place, so the two pieces shouldn’t move apart. There’s also some overlap built into the design. I would guess they were made that way to make them easier to get in and out of the car when cleaning.
methorian
Roanoke, VA
IT Admin
I may end up using some stronger double-sided tape to connect the two rear pieces.
That‘s certainly an option if they don’t stay together. I’ll try them as-is first and see if it’s an issue.
Don't forget they're form fitted to the footwell, so there shouldn't be much movement
Form fitment alone isn’t always enough to prevent all movement. But that coupled with the spikes should do a pretty good job of holding them tightly in place.
Form-fitting, spikes and the two pieces appear to attach at the top in the overlap. Those should all help tremendously. Then again, the back seat of ours will never be occupied for all practical purposes so how would I even know? :)
