Wheel lock sizing? Recommendations?
AlpaChino
JB
Indiana
2025 Kia EV9 Land
Has anyone purchased wheel locks for their MMR premium? If so, is there a specific size or brand I should be looking at?
Thank you!
Wheel locks are basically a waste of money. They can be easily defeated (I won't say how, a simple Google search will reveal that). The Mach-E wheels, and tires, are nothing special, I suspect many others will be higher on the list especially truck aftermarket rims.
Murse-In-Airy
Chaumont, NY
Mach-E ER AWD
Nurse
ChuckA
Chuck
North Branford, CT
Accountant-Retired
Thank you!
I got the part number from ford.com accessories and bought them on eBay for $35. I never installed them since I decided they’re not needed.
Hdscreens
2021 Mach E
Can anyone confirm if GR3Z1A043A fits regular GT black wheels? Dealer ordered EK4Z-1A043-A but they aren’t correct ones for the regular GT wheels. They stick out a lot and the Hex size isn’t the same as rest of lugs.
ChuckA
Chuck
North Branford, CT
Accountant-Retired
This is a picture of the GR3Z-1A043-A that are made by McGard and sold by Ford. Maybe you can tell by the picture. On Ford.com can you see the part number they list? I will measure the dimensions if that will help. I didn’t install them yet.
Ford Mustang Mach-E Wheel lock sizing? Recommendations? 528AB5A2-FF12-46FE-BE04-9E16B7BD24FE
Hdscreens
2021 Mach E
GR3Z-1A043-A is the part number that shows up when I search on fordparts or ford accessories. Based on info I gave to dealer they showed part number EK4Z-1A043-A and that’s what they gave me. When I looked up part EK4Z-1A043-A on fordparts that part number does indeed say for mustang Mach e.
Just want to be sure GR3Z-1A043-A is the correct part before I order. Would suck if it’s the same issue as the EK4Z version.
ChuckA
Chuck
North Branford, CT
Accountant-Retired
Bring one of your lugs to a different Ford dealer so you can compare to the lock lug before opening the package.
Hdscreens
2021 Mach E
Thanks for suggestion, one dealer out of 6 might actually have in stock. Will try that tomorrow.
MoonRiver
Tampa Bay, FL
Thank you!
I just got a set from Amazon
https://www.amazon.com/Veritek-14x1-5mm-Conical-Mustang-Lincoln/dp/B07VHYF14W/ref=sr_1_20?crid=XZ4R3M2CQWUJ&keywords=Set+of+4+Veritek+14x1.5mm+15+Inch+22mm+Hex+Chrome+Large+Acorn+Conical+Seat+Wheel+Locks&qid=1662650838&s=automotive&sprefix=set+of+4+veritek+14x1.5mm+15+inch+22mm+hex+chrome+large+acorn+conical+seat+wheel+locks,automotive,88&sr=1-20
They are just 20 grams heavier that stock wheel nut and 1.5 inch total length vs 1.45 inch of stock.
They fit well but only one thing though, the key is 22 mm hex not the same as other nuts so I had to buy a 22 mm socket for it.
Ford Mustang Mach-E Wheel lock sizing? Recommendations? IMG_4355
Ford Mustang Mach-E Wheel lock sizing? Recommendations? IMG_4353
wheel lock on wheel close up view
Ford Mustang Mach-E Wheel lock sizing? Recommendations? IMG_4354
stock nut on wheel close up view
Ford Mustang Mach-E Wheel lock sizing? Recommendations? IMG_4332
