Where did Software Updates go?
MacherAWD
North Shore MA
Healthcare Software
You don't see the Software Update on the left side of the Controls screen?
Wait you leave Auto Hold on with 1 Pedal? I thought you are supposed to disable that for 1PD, I know it messes you up in car washes.
Old_Norm
Old_Norm
Columbus Ohio
We've been doing it since we bought the MME. I don't use car washes but if I did I would just disable it. Haven't had a problem with AH and 1PD.
Nope. Auto Hold and 1PD have been working fine together for 3 years.
As far as car washes, it has caused absolutely no issue. Of course, I only do two-bucket hand washes.
MacherAWD
North Shore MA
Healthcare Software
But what is auto hold supposed to do in 1PD? The holds without rolling without it.
Just checked, per Ford it does nothing in this case:
Auto hold should be turned off when using one pedal drive
It auto holds the Mach E if 1PD is inadvertently turned off.
leehinde
Mach-E California Route 1
It doesn't mess up car washes. At least not the ones where you remain in the driver's set.
MacherAWD
North Shore MA
Healthcare Software
Correct, but doesn't do anything with 1PD and is intended to be turned off, per Ford. It's all good, was just making sure I wasn't missing anything
Just Lurking
Paul
Washington
2022 Mach-E GT
It’s $80 and you can use FordPass points.
That converts to half a cent per point. Anyone know if that's the standard conversion rate or if it differs by dealership or by the specific service/accessory?
I vaguely recall the manual saying to turn auto-hold with 1PD, but I figure if it needed to be off the car would turn it off automatically when switching to 1PD! Btw, the auto-car washes near me have the drivers shift into neutral.
Where does Ford say to turn off auto hold if 1PD is on?
On my Ford Dashboard page, Software Updates is no longer in the tabs under the picture of the car. I have automatic updates set up in the vehicle. It's been that way for a couple of days. Anyone else?
Just checked and I don’t see it either. That said, I never knew this existed on Ford.com.
What info was there previously? Just curious as my last OTA was Aug 7. Had dealer update my car manually in early Jan and now even the Aug 7 updated says incomplete in my car.
Old_Norm
Old_Norm
Columbus Ohio
The tile either said your software was up to date or that you had a pending update or that the last update was successful. I would guess that Ford will now only post the software tile if you have a pending update or the last, recent update was successful.
MacherAWD
North Shore MA
Healthcare Software
Old_Norm
Old_Norm
Columbus Ohio
The Software Update tab reappeared on my Ford.com Dashboard today. But the connected Services tab sends me to an Access Denied page.
YunniorO
Jacob
Westminster, Colorado
2021 Mach-E Premium AWD (Job 1)
May I ask why you use both? Is it bad to just let one pedal stop the vehicle for you and stay stopped? Is it more of an issue if someone read ends you?
