when the car is in navigation only prompt volume can be adjusted.Do you mean navigation from your phone, CarPlay/AA? Or vehicle Nav?
If vehicle nav, I have no idea. That shouldn't happen. But if it's CarPlay or AA, that has happened a few times before when the app developers introduce a bug where it continues to send that it's playing prompt audio to the vehicle but it isn't. The biggest offender for this had been Waze, and it was really annoying. As soon as you force closed it it would resolve. I haven't seen it in a while though.
If it is app based, you just have to wait for an update. If it's the vehicle nav though as noted I can't say, I don't have that issue on either Ford vehicle.
Wait until the navigation stops talking, then you should be able to adjust the regular volume instead of the prompt volume. If you are only able to adjust the prompt volume even when the navigation isn't speaking, then you have a glitch and should try the SYNC reboot trick.Does anyone know how you can change this without stopping your navigation route.
This^^Wait until the navigation stops talking, then you should be able to adjust the regular volume instead of the prompt volume. If you are only able to adjust the prompt volume even when the navigation isn't speaking, then you have a glitch and should try the SYNC reboot trick.
Yes it is the prompt volume even when not speaking. I even tried pulling the negative off the car battery to reset. I will ask dealership as it is going in for a recall appt soon. Thanks!Wait until the navigation stops talking, then you should be able to adjust the regular volume instead of the prompt volume. If you are only able to adjust the prompt volume even when the navigation isn't speaking, then you have a glitch and should try the SYNC reboot trick.
Just found this out, maybe this will change something...Yes it is the prompt volume even when not speaking. I even tried pulling the negative off the car battery to reset. I will ask dealership as it is going in for a recall appt soon. Thanks!
