I picked up my Mach-E yesterday and have the same problem with intermittent charging. I have an iPhone 12. At least I now know that it's not just me.I ended up adding a separate Qi MagSafe-compatible charger onto the other side. Definitely holds a charge now.
I've seen others utilize the dash mount as an alternative option. I personally wanted to keep my dash clean.
Neat. Any photos?SO, I think there are two problems. Are you using wireless CarPlay? I think that spends a lot of energy - about the same as you are getting from the Qi charger if it is not aligned perfectly. Second, the rubber mat that comes with the car, combined with your case, it's just too think for good charge to go through. It takes very little distance between the charger and the phone to get little if any charge.
I went to JoAnn fabrics and got a foot of this for $3. https://www.joann.com/vinyl-coated-outdoor-fabric-black/17687179.html Using the rubber mat as a guide, I cut the same shape out and tossed it in the console. It's about 1mm thick, and it's kinda tacky. And since it is a weave, you can see exactly where the charger is. I have not had the problem since switching to this.
This is a nice option. A variation would be to run that USB-C cord back to the port on the rear of the center console. The ports back there are power only, whereas the ones in the front to which you connected your cord are power and data ports. That way you would still have access to the front port for data connections.I ended up adding a separate Qi MagSafe-compatible charger onto the other side. Definitely holds a charge now.
photo?I ended up just adding my on Qi charger. I cut a square hole in the mat so that my phone could lie directly on they factory charger and even without a case, it would not stay charging. So I bought a new mat (since I cut a hole in the old one) and just plugged in a Qi Magsafe charger and put a little piece of double sided tape on the underside. Works perfectly.
