- Jul 1, 2021
- SE MI
- 2022 Mach-E Premium 4X, 2022 Lightning Lariat ER
I had an electrician install breaker, wiring, and my JB48 charger. I had them use 4 conductor wiring, even though the JB only needs 2 hots and a ground, so I had more flexibility in the future. In my installation, the white neutral is capped in the box.
I am considering adding an outlet to a box connected to the side of the workbox. Probably a 14-50 to allow me to use the Ford charger, depending on if I buy a 240v air compressor and what it's plug is.
I'm getting estimates for a whole house generator currently and may fold installing this into that work.
Question - what is code for the other end of the white wire in the breaker panel? Would they cap it, or would they hook it up to neutral knowing they would not be using it?
It is 4 gauge with a 6 gauge ground not that it matters for this question.
