Would these 21s fit?
RDZ89
RICK
Martinez,CA
2021 GB ME GT
Aircraft Mechanic
Hello all i am looking at a set of wheels that are 21x9 +35 21x10.5 +42 on my Mach e GT?
The tires would be 255/35 and 275/35
Hi Rick, the wheels will fit however you will get some poke on rears with a +42mm offset. It should be around +47mm. The fronts will fit just about flush.
The issues however are the tires. While the 275/35's in the rear have the proper load rating, the 255/35's up front do not. Not like you cannot run those tires but I personally would not run a tire with a load rating less than what Ford recommends. Trying to find a staggered setup with 21" or 22" wheels/tires is not easy if you want to stick to the recommended load rating. 20" is much easier and I explain a lot of this in a thread I just posted.
https://www.macheforum.com/site/thr...ggered-wheel-tire-setup-info-and-specs.28097/
