2 WiFi Connections, which does what?
Gullwingdmc
Gullwingdmc
Chip
Boston, MA
I can see if it has failed updates.
I think I’ve gotten all the updates so far. 1.6 and 1.4 installed fine, weirdly while I was at work. I just want to make sure everything is work correctly for when 1.7.1 ever rolls out, and Blue Cruise
TCU = telematics control unit or the cell modem
WSM = workshop manual.
Nice, thanks for the explanation. Is the WSM available to download anywhere? I love browsing through that stuff.
Gullwingdmc
Gullwingdmc
Chip
Boston, MA
The "mdm" connection seems to be sending things to Ford and connects more often whereas the "sync" connection seems to be updating maps (Garmin and TomTom).
Thanks for the info! I wish my router (ASUS) had this level of device logging. I need to dig more to see if I can access it.
CHeil402
King of Prussia, PA
2017 Audi A4, 2021 MME
Electrical Engineer
CHeil402
King of Prussia, PA
Electrical Engineer
Welp, I tried forgetting the network and now it won’t reconnect ?
Does your car just give you an error message? Maybe try restarting your router as well then reconnecting from the car. Perhaps the car's MAC address is stuck in the cache of the router...? Wishful thinking, but I hope it works, although the Wi-Fi connection isn't essential by any means up to this point. All of my OTA's came over the cell thus far. Mine was disconnect from my Wi-Fi for months before I even noticed.
Gullwingdmc
Gullwingdmc
Chip
Boston, MA
Restarted the router, the car, and sync. Still said “failed to connect”. Then I grabbed my iPad to see if it would connect to the hotspot. Tried connecting to my home WiFi one more time, and it worked!
Interestingly when it connected I looked at the IP and it was the MDM device that was connected.
Hopefully it sticks.
TruWrecks
Doug
Are you running a hidden SSID? the Mach-E TCU doesn't like connecting to hidden networks.
Hiding a network is not that effective anymore anyway. Someone with the right app on an android phone can run a scan an find every hidden network nearby in a few seconds.
Gullwingdmc
Gullwingdmc
Chip
Boston, MA
No it’s visible. No weird characters in the name or PW. Also made sure I was using the correct keyboard on the screen.
krafty81
Terry
Is update 1.6 thr most current? That is what mine says.
Gullwingdmc
Gullwingdmc
Chip
Boston, MA
Depending on what order you got them. Some people got 1.4 then 1.6. Others got 1.6, then 1.4. They are not necessarily sequential.
SAM
SAM
A little bit of a mystical kingdom, like Camelot
Premium MME4X Iconic Silver
I got 1.6 first, then 1.4 a few days later. So, car lists 1.4 as most current for me. Not intuitive.
Gullwingdmc
Gullwingdmc
Chip
Boston, MA
Unless you have a dinosaur ASUS router it should show up Traffic Analyzer
I didn’t have that enabled, I do now. It’s a newer mesh one so I figured there was something I was missing. It still doesn’t list what sites each device is hitting.
SAM
SAM
Thanks for starting this thread. I went to the car and WiFi didn't appear to be connected. So, I just pressed connect and it did so (it remembered my info).
When I selected mdm9650-tcu in the clients drop down menu and monthly in the timing drop down menu in the Traffic Analyzer Statistics tab on my Asus router, mdm9650-tcu had never connected in the last month (only one month of data is saved). It's connecting several time a day now that I connected the car again.
At first, I did not see SYNC listed in the clients drop down menu, but I do now. From data in the monthly view, SYNC has connected multiple times over the past month.
So, for me, it looks like SYNC was connecting but mdm9650-tcu was not.
