2024 Mach-E GT question
Fred Bombelyn
Fred
SC
2021 Escape PHEV, 2024 Mach-e GT
Recovering Engineer, retired
Just got my ordered in July Mach-E GT Friday, love it so far, looks like it's going to get over 300 miles/charge around town. But question: The screen behind the steering wheel has a lot of open space, and some of the indicators, especially the ones on the left side, are quite tiny and hard to read. Is there any way to make them bigger and possibly rearraign that screen?
MatchaGT
Brando
Huntington Beach
2024 Mach E GT w/performance upgrade
no way to make them bigger. there is no customizing in a large aspect, but you can add or delete the driver alert or having your cruise on or off will modify it, but that is really it. You can also put it on auto mode, dark or light mode.
Fred Bombelyn
Fred Bombelyn
Fred
SC
Also, I would like to be able to access the 12 volt battery terminals without having to remove two pieces of cowling. Would popping two holes above the terminals void the warranty?
Fred Bombelyn
Fred Bombelyn
Fred
SC
Well, hopefully Ford reads these posts and will correct this.
4wheeldog
7200' elevation New Messico
2024 Premium AWD Extended range
Retired a long time
Waiting for responses to this. I actually bought two plugs for the holes I anticipate boring. But I haven’t worked up the nerve to attack the cover on my pristine baby.
Fred Bombelyn
Fred Bombelyn
Fred
SC
How big are you going to make the holes? I'm thinking just big enough to attach my air pump.
4wheeldog
Retired a long time
As far as I remember, I bought 1 1/4” plugs. I want to be able to attach jumper cables or a battery charger without pulling the covers.
Sikkun
2023 Mach E
Cutting holes isn’t going to do anything to your warranty unless Ford can prove those holes caused whatever problem you’re trying to get covered.
Now they obviously are not going to replace the panel you cut holes in if it has some other defect later on.
