'25 GT center console compass
mcdevitt
Burnsville, MN
25 Mach-e GT
When I first picked up my (beautiful, blue) GT, I had the compass showing cardinal directions in the center console under the car image... I don't know what happened, but it's gone. Any thoughts on what setting I must have changed?
Manual says it's supposed to be there...
Ford Mustang Mach-E '25 GT center console compass tempImagew6vrhs
but I don't see it:
Ford Mustang Mach-E '25 GT center console compass tempImageOZWiSR
ReverendPete
Pete
Denver, CO
2023 MME Premium, 2018 Toyota Highlander Hybrid
Software Developer
My lowly '23 doesn't have that display arrangement... But the fact that it says "Compass or Outside Temperature" seems to me to imply that it's configurable somewhere, likely on the main screen somewhere under Vehicle settings... It might be worth searching for that and see if toggling it off and on (or from compass to temperature and back... 🤷‍♂️) makes any difference...
JohnFoxeSheets
San Francisco
johnfoxesheets.com
Have you looked through the settings for the car on the SYNC screen to see if there is a setting to turn on/off the compass (and temperature)? Since you have a 2025 (which has a substantially different IPC than previous year models), all us non-2025 owners can only guess.
mcdevitt
Burnsville, MN
25 Mach-e GT
Dealer checked another GT on the lot and see it. Neither dealer nor I have found anything in the vehicle settings… will continue the hunt
amaranth
NJ
Mach E GTPE '25
Mine showed twice so far. I saw an N once and was like wtf is that, then found out in the manual it was the compass. However it has only showed one more time since then...
Reactions: TWD
mcdevitt
Burnsville, MN
25 Mach-e GT
I've looked through everything and read the manual back to front... No joy in Mudville
mcdevitt
Burnsville, MN
25 Mach-e GT
Interesting... You change any settings?
TNGreenMachE
MIddleTN
24 Mach-E Premium RWD ER
Just a wild stab, try all 3 drive modes. The info displayed changes with the mode, or at least on a 24 it does.
eastern refugee
Rich
california
insurance agent
Question for those of you have a 2025-Does it have a direct port for Tesla or do you still have to use an adapter???
