NY_Cade69
Cade
PA ON NY
Ford might be waiting for a useable data file from Tesla.
Its not like there is a Ford employee sitting at a PC adding Superchargers on-by-one.
I hope... @Ford Motor Company say it ain't so! :D
DYohn
Valley of the Sun
2021 Mach E Premium Ex
dan_meh
Daniel
Alexandria, VA
Technical Writer
Here is your explanation:
https://www.macheforum.com/site/thr...to-the-built-in-navigation.51314/post-1044160
Bottom Line: it’s a Boolean value in the routing logic. There’s an IF statement that, in pseudo code is like “IF plug compatible.” In 2025 and later, you can express in a global setting that you are compatible with NACs/non magic dock stations because you have the adapter. All cars know they are compatible with CCS1 (North America is our scope here).
So, the charging station DB exists in the cloud and is updated to your vehicle if you have connected navigation. That station DB knows if stations are CCS (including magic dock) or NACs only. I’m aware of Tesla only sites but setting them aside. However, in 2024 and earlier, the IF statement can’t know if you have an adapter because there’s no global setting. In normal routing, where the system is adding stops for you, it skips all the NACs only sites because the logic fails the IF statement. As Charge_Rob says, that’s by design. They don’t want to route you to a place where you get stuck.
I suspect that @music_cities trick works because he’s skipping the IF statement, literally. I’m guessing that if you ran a trace, you’d see that direct navigation to the supercharger, you’d see that it skips the IF statement. It knows that you’re heading to a supercharger because the database is correct, and because it doesn’t calculate intermediate stations, it never checks compatibility.
@music_cities is exploiting a bug and I love it. Someone forgot to make Connected Navigation check compatibility with the IF statement in the case of direct navigation. The trick exploits the error to make Connected Navigation treat the Supercharger as always compatible.
Can I prove it? No, but it follows from what we know, and I have been to enough rodeos that I can 💯 imagine the backlog grooming where someone says, “We discovered a bug where direct navigation to a NACs site skips the IF statement.” And the group agrees that it’s not worth fixing.
NY_Cade69
Cade
PA ON NY
That explains why the nearest Supercharger to me doesn't show, but others do! (I have a '25)
I also noted that they are buried if you use the default sort order, you want to sort by distance to make any real sense.
I rarely noticed this as I typically go to a Ford/Shell system or EA.
silverelan
Seattle
Someone tell me if my summary is wrong.
  • 2021-2023.5 MMEs can precondition to Superchargers if they set the station as a destination.
  • Preconditioning is indicated by the destination icon being a charger icon (per @matwlev)
    Ford Mustang Mach-E Announcing: Tesla Superchargers + Connected Navigation IMG_6423
music_cities
Calgary, Canada
Mach E 2022 GT
Correct. However you can't search for a Tesla as a "Charger", you just have to search for it as a regular POI, like you would search for a museum, cafe, or tannery. Until you get the BIG SYNC UPDATE it doesn't show up in the charger search.
UnforAll
northern Virginia
'21 Mach-E 4x Premium IB; '24 Subaru Crosstrek Sport
Grad Student
How Add Preferred Charging Networks in Connected Navigation?
I'm following up on the post by @Jimrpa How Do You Specify Preferred Charging Networks in Ford Navigation? | 23 June 2024
With the Software Update 12 series of ECG, TCU, and APIM I no longer have to use the POI workaround and can now see and plan routes with Tesla Superchargers in the native nav after toggling Fast Charging Adapter needed.
Question: is it possible to add Preferred Charging Networks in Connected Navigation? In the Navigation settings is a screen with "Preferred Charging Networks" and "+ Add Preferred Network." But there is no list to choose from and selecting + Add Preferred Network and then manually typing an entry does not bring up any list. (see attached screenshot)
I realize it is possible to add Tesla Superchargers as a preferred network in Apple Maps. But what about in Connected Navigation?
@Ford Motor Company or other forum members, if I've missed the answer here or elsewhere, please let me know!
Ford Mustang Mach-E Announcing: Tesla Superchargers + Connected Navigation Navigation - Add Charging Networks
mdwinther35
Matt
SE Michigan
2023 Mach E Select AWD
Not aware of any way to add preferred networks in connected nav, but are you saying you now have the adapter toggle and the ability to route to superchargers (without the nearby poi hack)? If so what model year?
UnforAll
northern Virginia
Grad Student
Hi, yes. 2021 Job 1. SYNC/APIM completed successfully on 5 July after getting the ECG update on 10 June and TCU on 2 July. Each of those modules of "Software Update 12" have a thread as does the overall package. Here are a few: OTA "Software update 12 - Central Computer" | MachEforum - Ford Mustang Mach-E News, Owners, Discussions, Community and SYNC-26.2.8.3 (the big SYNC update) | MachEforum - Ford Mustang Mach-E News, Owners, Discussions, Community
fatjohn
2021 Mach e Premium
electrical technician
I got the sync update that said Apple Maps enables routing to EV chargers and pre-conditioning.
I installed Apple Maps on my iphone and used it for mach e navigation today. But I could not find an option to tell the car to pre-condition for our destination.
I tried searching the forum, and there are a lot of postings related to the topic, but I couldn't find a how-to.
Thanks, john
stellman
Austin, TX
2021 Mustang Mach-E GT
Thanks, john
Pre-Conditioning will happen automatically when the next destination in your route is a charger. You’ll see in your driver display the next destination milage number (far left, bottom-ish) will have a charger icon when it knows the next stop is a charger. There’s no way to force it, and no need to.
fatjohn
2021 Mach e Premium
Thanks Stellman
AZBill
Billyk24
William
PA
Job 1 2021 Premium. My experience is no battery pre conditioning occurs on route to a dcfc when the battery temperature is 59f or warmer Seen on carscanner pro app.
UnforAll
northern Virginia
Grad Student
You can add them, but only Magic Docks show up in Apple Maps, just like the old Ford Nav situation.
I also found that a few non-compatible Tesla sites now show up in the Ford Nav, after the Sync update. Seems to be the ones with a mix of V2 and V3 stalls.
Good to know, thanks!
