Apple Watch pairing to Mach-e
DavesMach
Princeton, NJ
Mach-E Premium
So I want to use my cellular enabled Apple Watch Ultra and take phone calls on my watch then run it to bluetooth on Mach-e. Has anyone been able to bluetooth pair their Apple Watch to the Mach-E???
JohnFoxeSheets
San Francisco
johnfoxesheets.com
There is a FP app for the Apple Watch, but all it does is allow you to start/stop and lock/unlock the doors. And to be clear, by start/stop, I mean like you would on the FP screen on your phone, not start and drive away like you would with Paak.
Ford Mustang Mach-E Apple Watch pairing to Mach-e incoming-A95690BE-8540-4F5F-8D22-206F6524F168
AFAIK, that's it for FP Apple Watch integration...
DavesMach
Princeton, NJ
Mach-E Premium
So unfortunately the FP app doesn’t work y less
So I’m speaking on taking phone calls off Apple Watch to Mach-E
Unfortunately the FP watch app doesn’t work unless you have your iPhone with you.
JohnFoxeSheets
San Francisco
johnfoxesheets.com
Oops, sorry I misread your post. I don't know that it's possible to do that... I also recently discovered that if you're on your Watch's cellular for a phone call, you can't even pass it to your iPhone if you come into range of it. (Or at least that's what happened when I tried it.) So I kinda doubt that the Watch would be able to pass to the car. I suppose you could try to pair the Watch to the car as headphones...?
bp99
22 MME eAWD, 21 MME CA Route 1 (sold)
In theory, the Mach E should look like a bluetooth headset to the watch when in pairing mode. No different than a pair of wireless earbuds. It should only take a minute to find out what happens when trying to pair.
DavesMach
Princeton, NJ
Mach-E Premium
Yes in theory. It doesn’t though. Was asking if anyone else was able to get it to pair.
Vulnox
Livonia, MI
The Apple Watch can't pair with a car head unit on most newer cars. You can search "Apple Watch pair to car bluetooth" and it's been answered a lot. The Mach-e won't be any different. It's a limitation on the watch side. I found it out months ago when I forgot my phone and tried to pair my watch to my F-150 bluetooth to play Apple Music.
It isn't exactly clear why, because it seems the Watch can connect sometimes to older vehicles, like 2018 or older. It may have something to do with the bluetooth profiles the watch supports compared to what most vehicles require these days, like secure pairing (PIN) or the actual audio profile.
https://discussions.apple.com/thread/253452107
Sounds like some were able to get it to work by buying a bluetooth adapter that plugs into USB and connecting to that adapter. Which makes me think it's down to the profiles that vehicles support and Apple not supporting them on the watch.
COACH CHRIS
C
NJ
Mustang Mach-E AWD Select
The Apple Watch can't pair with a car head unit on most newer cars. You can search "Apple Watch pair to car bluetooth" and it's been answered a lot. The Mach-e won't be any different. It's a limitation on the watch side ....
This is the correct answer, unfortunately. I suspect this limitation is in place for the same reason the Watch has any limitations in place: Battery life. Obviously with an Ultra you have a bit more wiggle room but I'd suspect not as much as you think. (As an aside, I also have the Ultra and wow is the battery life fantastic for what it was designed to do. Color outside those lines, however, and who knows.)
2026 Velocity Blue GT/CS
The issue was actually answered a while back in another context (I think the Apple Support Forums). Pairing Apple Watch as a “phone” to car systems is not permitted because of the battery drain on the watch. The cellular feature of Apple Watch is envisioned to be used for relatively short, fairly infrequent calls, unlike iPhone, which is actually meant to be used like, well, a phone. This is also why Apple is a bit touchy about apps that have continuous or high-rate data connections to Apple Watch (no native browser, no streaming video apps, etc.)
