Battery range less than official figures
Phil-Springs
Phil
Colorado Springs
Mach E CA RT1 AWD Extended DMG 2022
They do. It's the GOM.
The GOM and nav don’t take into account elevation change, climate controls, outside temp , or speed you plan to drive. So, I’m not sure your reply is valid or helpful.
Not at all. It uses all of those from past driving but knows nothing about where you are going next.
I agree but that is my point. It takes all those into account based on past driving, but also current battery and climate conditions.
timbop
I believe you are at least partially mistaken: it CLEARLY takes current ambient temperature into account. It also clearly tries to factor in past driving habits, which is why resetting history makes such a big change. Using the nav, it does anecdotally make a better estimate. Unless you are privy to Ford's algorithm, we are simply guessing about how the GOM works - which is ironic to say the least ?.
Rory
Rory
Davis, California
Mustang Mach-E 2022 Premium ER AWD
Additionally to what @Kabish said, the battery chemistry is less active when the battery is cold. The colder it gets, the less active it is. When the chemistry is less active, it holds less charge, which is the crux of the problem. If you can keep your battery at 70 degrees F all the time, you will not have these issues. Unfortunately, there is no way to keep the battery always at 70 degrees F. ?‍♂?
Actually, it both holds less and releases less. If you warm up the battery, you may get better range as it can use more of the stored-up charge in the battery. See this post by Mach-Lee for a graph showing the effect.
Shayne
Northern Ontario Canada
2021 MME4x Prem
Helps to start to understand your consumption for different situations and don't count on the GOM blindly. There can easily be a 15% consumption swing based on head vs tail winds. Does the NAV take your travel time winds into account? The GOM should take the ambient temperature factor into account but a change in your speed, winds and plowing though snow are on you. Finding it takes more planning/thinking which may be the case until chargers out number gas pumps up here.
I do think range can be improved by taking into account the route you have chosen in the navigation system. But do we know for a fact it doesn't?
On all the trips I have taken when I have used the navigation, it has been very accurate. It assumes I will drive slower than I actually drive, so the estimated charge at destination usually drops as I am driving. But should it assume I am going to speed, and can it know when I will smash the go pedal for some WOT fun?
If I drive close to the speed limit, the estimate is usually very, very close. So is it using the route, or just using my driving history, battey condition, and current climate? It is possible my driving history is consistent enough for the an accurate prediction. Or maybe it really is using the route as an input. If not, it should.
JRSNoVa
Northern VA
2023 GT Performance Grabber Blue
Thx. I think my post was misunderstood. I understand that weather conditions and driving style influences actual miles achieved on a charge. But if the battery has capacity of 314, shouldn't it charge to that level? I may not get 314 based on conditions and speed but it ought to fully charge.
The battery doesn't charge to a range, just like you didn't fill your ICE car with miles. The electricity is the fuel that powers the car. How far it goes depends on multiple factors, as you're finding out. Same was true of ICE cars but there was less need to keep track with fuel available everywhere.
Shayne
2021 MME4x Prem
The good thing is max range only really matters when you are on trips using DCFC and knowing the distances between chargers coming up. For the majority of my ownerships I have charged at home which was never the case for gas cars. The range is normally enough for the majority of peoples normal day commutes and when you come home you just plug it in. It comes on at night and charges it to the charging schedule that you set up and you are ready again to go for the next morning. Never drive into a gas station again. Fill up with cheaper energy at the comfort of your home.
You can play with ABRP and adjust the temp, wind etc. even snow and see what happens for different virtual trips. I just use Plugshare now to get the best way I know so far of determining if the next set of chargers I need are working or are down.
Awmustang
Andy
The EPA range is based on defined driving conditions and speeds that you may not achieve if your condition or speed are different. If you drive a constant 55 mph in 68 F on flat roads with no head wind you will get over the EPA range however at 70 mph you will not. This is the same for ICE and their EPA ratings. Just never thought as much about EPA with ICE.
That is the shortest form reply I can come up with. There are a "few" threads like yours you can search for for more info.
Actually the EPA published range is a combined range that factors in some city driving so it's inflated even more than just driving at 55. One of my major complaints with that range. Much like ICE cars get a city and hwy MPG, EVs should get a hwy only range figure. I believe Ford under reports their official EPA range so it's closer to the highway range you might actually see.
I think a steady state, 75 mph at 70 F EPA estimate would be great.
Awmustang
Andy
There's a couple youtube channels that do 70 mph range tests. And Car and Driver does a 75mph range test. So the data is out there, but I agree, it should be on the window sticker.
hprose
Harvey
Pinellas Park FL
F250 and a Mach-e on order
Financial Advisor
I have a California Route 66 with an extended range battery. It's supposed to get 314 miles on a charge but it charges to 271 and the home charger is set to to 100%. Anyone have a similar issue?
I have a 22 GT. Estimated range 270. Actual range was 272 until I started using unbridled. Now 282. 70 degrees. I drive like a normal person - accelerate and decelerate smoothly. When using engaged I glide to stops with light braking. Check your driving scores.
  • Like
Reactions: JLH
hprose
Harvey
Pinellas Park FL
Financial Advisor
Only a matter of time until Ford patches this to always show full range at 100% and just have it recalculate later to stop this nonsense
I charge to 80. Take range, divide by 4 multiply by 5.
timbop
Yes but the "range" value in your statement is using Ford's conservative algorithm so your result can (and often will) be different than simply displaying a value based off the epa range x current charge.
