Battery usage at 100%
Anwarlucas
Anwar
Minnesota
2023 Mach E GT
I'm experiencing a weird situation with my 2023 GT and wondering if the battery is over charging or the percentage display is inaccurate, I usually charge to 90% daily however have charged to 100% less than 6 times and on each usage after charging to 100% I can drive an astounding amount of miles before the car drops to 99% then afterwards it does appear to drop in percentage as you would expect but that first percent at 100% seems to be off by about 3% or so, see images of the drive today, 44° in Minneapolis
1% gave me roughly 15.6 miles drive, the 2nd percentage gave me 3.9 miles driven..
Can or does the battery need be recalibrated?
Ford Mustang Mach-E Battery usage at 100% IMG20231222171420
Ford Mustang Mach-E Battery usage at 100% IMG20231222171425
Ford Mustang Mach-E Battery usage at 100% IMG20231222172111
Ford Mustang Mach-E Battery usage at 100% IMG20231222172117
JamieGeek
Southeastern Michigan
spareelectrons.wordpress.com
Nope very common thing to happen.
You're good.
BMT1071
Glendale, AZ
21 MME SR RWD, 23 MME GTPE
EV Technical Trainer
Did you precondition? That always makes a difference for my car as to how quickly the first percent or two drops.
Anwarlucas
Anwar
Minnesota
2023 Mach E GT
I did not precondition however I did this drive about 2 hours after it had reached 100% plugged in at home using an autel charger
@Mach-Lee is an expert in this area, but I will share my opinion.
Battery capacity increases when it is warm, and decreases when it is cold. So if you charge the car to 100%, that might be 88 kWh (assuming you have less than 100% SoH). If you charged the car in a fairly warm garage, but then are driving where it is very cold, the battery capacity could actually decrease as you drive. So as the battery cools, it may have a maximum capacity of 85 kWh, for example. Even though you are using capacity, as the battery cools the BMS thinks the SoC is still at 100%.
So it stays there for longer because of - winter. And you live in the Great White North, almost. ?
There is some hysteresis in the SoC at 100% so it doesn't drop to 99% as soon as you start the car. How long it sits there can be affected by temperature changes. It also depends how balanced the pack is at 100%.
But as everyone else is saying, it's normal. No problems here.
Anwarlucas
Anwar
Minnesota
2023 Mach E GT
Thank you all for the knowledge and reassurance, I appreciate you all!
MachEMaster
Will
Canada
1997 GMC Yukon GT
Aircraft Maintenance Engineer
You are Givin' 'Er 110%
Steve4GT
Madison, WI
2021 Mustang Mach-E GT
IT Guy
I know! I experienced this the other day as well for the first time. I used to have a dual motor Volkswagen and it would go down to 99 after about 5 miles ?
