- Jim
- Sep 10, 2020
- Wayne, PA
- 2021 Infinite Blue Premium Mustang Mach E ER AWD
- Retied (formerly tried to herd highly technical, independent cats)
Thanks all! I had no idea that aerodynamic drag was THAT large of a factor between 60 MPH and ~ 120 MPH. I did consider thermal effects on drivetrain components and assumed that, at least until around ~120 MPH, the thermal management systems kept those relatively constant (for example, the battery would deliver the same energy to the motors, regardless of speed, at least until 120 MPH).Basic Physics....You're not operating in a vacuum. As you push more against the air it pushes back and it needs more and more power to accelerate at the same rate, which it doesn't have because the power is flat.
But it's also not flat. As you gain in speed, the amount of power available drops for thermal control and battery health. Additionally, the longer you accelerate the more power is pulled for the same reasons.
They changed the rear motor to the one used in the lightning and gave an available performance upgrade package for purchase which boosts power and reduced the power throttling which gave a significant decrease in both 0-60, 1/4 mile times and an increase in trap speed from 102 to 115 mph.
