Blur on 360 camera
cbcasas
Christopher
2024 Premium
Has anyone seen this odd blur on the 360 camera? It cleared away after I restarted the car, but thought it was odd.
Ford Mustang Mach-E Blur on 360 camera BB153C85-8839-44C1-8C55-649EA23E929C
Pioneer74
Dearborn
2022 Lightning Lariat ER - 2025 Mach-E Premium ER
That means that camera isn't communicating. Could be the camera itself or the connection.
cbcasas
cbcasas
Christopher
2024 Premium
Pioneer74
Dearborn
Also, all was fine after a car restart. Must be software related?
I'm not saying it isn't, but when I've seen the image do that it's usually a hardware problem.
MachEMaster
Will
Canada
1997 GMC Yukon GT
Aircraft Maintenance Engineer
Could just be picking up a weird Hue/Anomaly from the blue line and handicap parking spot to the right?
cbcasas
cbcasas
Christopher
2024 Premium
Could be! Thought it was weird. Plugged into FDRS and seeing CMR B15E2:97 stating Passenger Side LED obstructed or blocked. Weird
ripperAZ
Ripper
AZ DESERT
UV and blue light coatings on lenses to protect them diffract external rays into optical dispersive colors on lcds. It is not software or hardware. It is purely optics
Jes sayin
cbcasas
cbcasas
Christopher
2024 Premium
Jes sayin
So too much light on the LCD screen?
Pioneer74
Dearborn
Thanks, which cameras are the culprit in this case? The cameras on the side view mirror?
Side mirror. The image is stitched together from 4 cameras. Only the passenger mirror is blue.
Ford had a problem back in 2019/20 across multiple vehicles for bad cameras resulting in a recall. That is what the screen displayed when the camera was bad.
Because it worked after a restart I would first check the connection, or have a dealer look at it.
cbcasas
cbcasas
Christopher
2024 Premium
I see what you mean now--after looking at the issue in the F-150's. Do you know where the connections are in the Mach-E's?
Pioneer74
Dearborn
No. Sorry. I don't even have mine yet. :)
ripperAZ
Ripper
AZ DESERT
Under the right glare conditions outside the lens coatings on the external cameras can exhibit optical dispersion anomalies. They will always clear themselves up on movement or a screen refresh
Jes sayin. See it all the time in sunny ? glare filled az. Best Solutions to look away for a few seconds.
