Cases for Ford/Lectron Adapter
CameraCarl
Karl
Twin Cities
After searching for suggestions about a case to buy for my new adapter, decided to order three different cases for the Ford adapter to see which might work best. Here are some photos and comments in case anyone is interested.
Ford Mustang Mach-E Cases for Ford/Lectron Adapter Adapter Cases (1 of 12)
_____________________________
The first case is a hard shell. The adapter is a tight fit, but should fit better if the honeycomb padding sheet were cut out. You can still zip the case closed, but it bulges quite a bit. This case is twice as expensive as the softer cases, so I decided to return it.
https://www.amazon.com/dp/B0D5LVWWNZ?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
Ford Mustang Mach-E Cases for Ford/Lectron Adapter Adapter Cases (2 of 12)
Ford Mustang Mach-E Cases for Ford/Lectron Adapter Adapter Cases (4 of 12)
The next two cases are soft. Both come from China and may very well have been manufactured at the same place, but Amazon sells them through two different vendors, packages them differently and charges a different amount for each.
The first is a leatherette material and only seems to come in this one color. The case is slightly padded, but the adapter fits rather well and the case only bulges a little bit when zipped shut. I'm not sure how durable the leatherette material will be, but it seems smooth/slippery enough to resist staining and might wipe clean.
https://www.amazon.com/dp/B0D7C5DXL3?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
Ford Mustang Mach-E Cases for Ford/Lectron Adapter Adapter Cases (5 of 12)
Ford Mustang Mach-E Cases for Ford/Lectron Adapter Adapter Cases (8 of 12)
Ford Mustang Mach-E Cases for Ford/Lectron Adapter Adapter Cases (7 of 12)
The last case comes in many colors. It is a smooth, but slightly textured fabric. It seems that it might be a bit more durable/rip-resistant than the leatherette case, but it also might stain more easily and dirt might not wipe off as well. The case is slightly padded and the adapter fits inisde was well as in the above case. Both zip shut easily.
https://www.amazon.com/dp/B0CWZWD264?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
Ford Mustang Mach-E Cases for Ford/Lectron Adapter Adapter Cases (9 of 12)
Ford Mustang Mach-E Cases for Ford/Lectron Adapter Adapter Cases (10 of 12)
Ford Mustang Mach-E Cases for Ford/Lectron Adapter Adapter Cases (11 of 12)
Ford Mustang Mach-E Cases for Ford/Lectron Adapter Adapter Cases (12 of 12)
So, there you have it. I am still trying to decide between the red and greenish case. Both are very similar. I guess the choice will be whether I want one that might be more resistant to stains and more easily cleaned or the red one which might be more resistant to scrapes and tears.
AliRafiee
Ali
Seattle WA
2022 Mach E GT - Grabber Blue
Software Eng.
The hard case is the one I have
Maui
Austin, TX
2024 Mach-E Premium
Software
is there a reason to get a case at all? They "look" to be fairly study adapters on their own. Do they need protecting?
grein002
Scott
Durham, NC
I would probably like a case of some sort just to prevent the hard plastic adapter from hitting other things / vehicle bits while vehicle is in motion. Don't think the adapter itself probably needs protection.
ipca204
2024 GT PE, 2023 VW ID.4, 2025 Equinox EV
you people with your useless cases....cracks me up! Keep the posts coming!
AtomicInternet
SC
Focus RS, Mach E Premium
david_quick
Bremerton WA
2023 Mach E GT
I used the A2Z case when they recalled their first edition. The replacement was bigger and came with a new case so I slapped a Ford sticker on the old case and put in the Ford adapter in it.
Kawika
Kawika
Santa Barbara
2923 GTPE
Snowboard guide
Just got my adaptor yesterday and the box it comes in is pretty sturdy so I am keeping it.
Silly aftermarket cases.
