Kabish
- Bill
- Jul 24, 2021
- San Diego
- 2021 Mach-E Mustang
- IT
So I'm not sure if this is an iOS 15 thing or if this is something that Ford changed with the latest version of FordPass. I know a few people leave their phones in thier cars so I waned to pass this along.
Apparently now when you turn on Airplane mode it no longer kills the connection between your phone and your car. Typically when I hit airplane mode I'll get the "key not detected" error pretty soon after. Today I happened to notice that I did not get the error when getting out of my car. I had already opened my door so I got back in and pushed the start button and imagen my surprise when the car turned on.. I double checked that Airplane mode did indeed turn on and it had bluetooth shut off (technically you can be in airplane mode with BT on). I ended up turning off my phone and then I got the key not detected error.
I know in the past even with my phone on and airplane mode OFF I could not unlock my doors if I manually locked them via 7-8 9-0 buttons even if my phone was still inside the car. I might have to test this out again to make sure its still functioning that way.
So, either FordPass 3.31 doing this to try to keep PAAK working, or its an iOS issue. I'm leaning towards it being FordPass as I noticed when 3.30 (one version back) when you closed the FordPass app it no longer comes up with that notification saying FordPass performs best when left opened. I also noticed even with FordPass "closed" that the PAAK still worked... That said, I believe iOS has had some past history with airplane mode flaking out with new release. Guess the only way to know is if still still has iOS 14.8 that can test it /shrug
