Martin desbrulais
- Martin
- Jan 21, 2022
- Aylesbury
- Mach E RWD Extended range
- Electrical Engineer
Same issue 4 days ago on my 19-1-22 Mach E X
Checked my App, charge had stopped on my Zappi and also on the Zappi the front was lit red and not blue, went to unplug the car and was unable as it wouldn’t release , entered the car, switched the ign on and a showing of a yellow cable and a spanner either side of the handbrake sign as well as a service required warning, went to the plug and this time I was able to be releasE it also prior to releasing it the charge indicator was lit orange, left it 2 hours and same again but this time no spanner light, now regularly I try to charge, the plug releases , the charge light are white and still my Zappi charger is showing red with no fault codes.
My voice activation also comes on regularly without me talking and touching nothing wheel.
I also get very loud creaking from the OSF when pulling away.
Spoke to the MACH E technical department and am awaiting a booking into a Ford dealershi,will keep you updated.
