LuppensG
- Guus
- Jul 8, 2023
- Belgium
- Tesla Model S, Ford Mach-E
Hi,
We have an SMA EV-charger 22kW 3P which has the possibility to charge on 100% solar power. In this mode, the charger will ramp up and down the charging current to the car, in function of the available excess solar power.
For some reason, the car don't start charging or stops charging after a few seconds. The charging station says that the car interrupted the charging process. The car says there is a problem with the charging station...
When we put it in full power mode, all is fine and charging goes well.
We also tested the car at another SMA EV charger, but the single phase version (7.4kW)
Here, the dynamic solar charging mode DOES work fine! The problem occurs only at the 3-phase charger.
Any ideas?
Thanks!
Any ideas?
Thanks!
