Charging Set up
Larslarson
3423 Soyla Dr., Oceanside, ca
Mustang Mach e route 1
New to electric vehicles . Getting my Mach e route in a couple weeks. Did anyone use an electrician outside of the Ford recommended one? Can anyone recommend one for Oceanside CA?
4sallypat
Pat
www.kudo-ume-farms.com
Network Tech
Get quotes for 240V installs from a couple of electricians.
Check with your utility company to see if they offer a discount by getting a separate meter or TOU (time of use) plan.
When I got mine installed a couple of years ago, I had 3 electricians bid on the job and the price ranged from $500 to $1600.
My utility company (SCE) suggested a separate meter installed but my electrician said it's only beneficial if you have a full on EV battery to charge. My car is a PHEV.
Also make sure if any permits are needed, to have the electrician pull them.
Your install will vary in cost tremendously depending on distance from the meter, sub panels, conduit runs, and amount of wiring.
My new house has the meter on the same wall as my garage so it will be uber cheap when I get my EV....
Chuck
Chuck
SoCal
Mustang Mach E 2021
I used an electrician that only does EV charger installs. He was fast, about an hour, and the cost including parts was $500. He's making a killing.
krafty81
Terry
My guy charged 300 to install my CP. PM me if you would like his info.
Pidg133
2022 Select Rapid red & ordered 2022 GT Ice Blue
Used a local electrician to do the install for $200 after I failed to do it myself. My house was setup (box, conduit, etc) for everything and just needed the wiring, plug, and breaker.
