Charging Speed - Mustang Mach E Premium - Only 80KWS Max
dolvio
Canada
2024 Select
To be clear, the preconditioning starts at 30km (18.6 miles) from the charger. 8 minutes isn't going to do anything. Couple that with arriving at 58%. And the battery wasn't 6C, it was likely colder.
I can understand that completely. I can’t imagine anyone using the chargers around here are driving from at least 30km’s away. The battery was probably warmer than 6C as it was in my garage before my short trip. This is a hyper charger (380kwh) and getting 55kwh is a joke. I’ve been able to get 60kwh at a 180kwh shared power charger.
Nobody charging around me is likely ever under optimal charging conditions. It’s all short trips, no pre conditioning, cooler weather right now yet my car is charging at half the speed as everyone else. I just don’t get it.
Space_Pony
Indiana
2023 Premium Mach-E awdX
It sounds like you're describing optimal conditions for a L2 EVSE in your garage.
Billyk24
William
PA
Err..... hyper charger (380kwh) and getting 55kwh is a joke. I’ve been able to get 60kwh at a 180kwh shared power charger. -----could you tell us what a charging curve is?
dolvio
Canada
2024 Select
Not sure I understand what your message is about.
music_cities
Calgary, Canada
Mach E 2022 GT
There’s a lot of irrelevant and irreverent advice in this thread!
Another thing you can do is find a nice hotel with an L2 charger and a good honeymoon suite and take your spouse (or lover, or random hookup) there and charge overnight while you enjoy each other’s “company”. Free charging!!!! The slower the better in that situation.
SaintKevin
SaintKevin
Chicago
Ford Mach E 2025 Premium
haha where do you find the spouse, love, or random hookup to test this method?
devmach-e
SF Bay Area
Unix Sysadmin
Not sure what that really means.
It means they should install an L2 EVSE at home and avoid having to go to DC fast chargers.
devmach-e
SF Bay Area
Unix Sysadmin
The chargers are rated in kW, not kWh. kWh is what makes it into your battery and what it can hold.
A charging curve means that it starts out at 150 kW at low SOC, and as the battery "fills up", the kW tapers over time. So while you are getting a high rate at 50% to 70% SOC, it gradually tapers to less than 60 kW when you get to 80% SOC, and then further drops to less than 30 kW as you pass 90% SOC.
devmach-e
SF Bay Area
Unix Sysadmin
We go once a month for the sake of it.
Why pay higher prices if you don't have to? There's DC fast chargers just down the street from work, but I use the work-provided ones because they are only 20 cents a kWh instead of the 50+ cents that EA charges.
dolvio
Canada
2024 Select
Yep, I know. Thanks.
Billyk24
William
PA
SaintKevin is the author of kWh statement. I'm not sure he understand this DCFC business.
devmach-e
SF Bay Area
Unix Sysadmin
I quoted your specific post which used kWh. Apparently both of you used kWh when you should've used kW.
SaintKevin
SaintKevin
Chicago
Yes, that was new EV driver misspeak. Being a month in I'm more tuned to the frequencies and terminology now, but still a lot to learn.
