kltye
- May 21, 2021
- Chicago
- IB MME Premium RWD
That's if we want to upgrade to wildly faster charging and/or 800v architecture. But what if, after 10+ years, your pack capacity has dropped by say 15%, and you wanted more capacity then? We could still use the same cell configuration, but use cells with higher energy density. That actually happened with late model Fusion Energis; they added capacity (with an increase in weight), but kept the same form factor and space used.A more apt metaphor would be changing from a 32 bit to 64 bit cpu. You can't just replace the cpu; the bus and everything else has to be upgraded. In a computer that's pretty easy and inexpensive to replace the guts inside of the case, even though it requires changing almost everything except the peripherals (potentially including the power supply). Doing that in a car is problematic.
As @Maquis said the cheaper procedure would be to replace the car.
