- Mark
- Nov 13, 2019
- Sonora, CA
- Currently: '20 Shelby GT500 FPB '24 Mach-E GTP GGM
- Retired
Finally got around to installing the armrest that I custom ordered from Miguel @miguelmix. In my '21, I had an auto upholstery shop recover the armrest and they did a great job of closely matching the Ford Performance Gray interior of the GTPE. Since I was purchasing several other items for my '24 from Miguel thought I would order this from him too. The difference is, he sells the entire armrest so I didn't need to be without mine for a couple of weeks. Also, he uses the Chinese version which is not tapered at the end (it's 1.25" wider) and looks/feels a bit more substantial.
I wanted the leather and Alcantara to match the interior including the silver stitching and he did a great job. You can never get the colors perfect unless you're using the same exact materials but it's close enough. I wanted the pattern to be the same and didn't want any custom embossing or stitching like "GT". Also had him add slightly more padding so it feels nicer to the touch. It's super easy to remove/install armrest. Lift up fully, pull off the two plastic hinge covers, remove two bolts, one on each hinge and lift out armrest.
Difference in size/shape between OEM and Chinese armrest:
Installed:
Installed:
