Dash Cam install
tinman
V
chicago
Mach E 2024
where do you guys get the dash cams installed ? i am not very tech savvy and previously did it at Bestbuy for my other car but looks like its not an option anymore ?
is it easy enough to install one without much tinkering ?
Did my own. Used a fuse box kit because I don’t want to overload the mirror circuit. It wasn’t that hard. Installing the new one in my new car soon. ??
MUSTGLFR
Walter
Mississauga, Ontario
www.efficient2Sustainable.ca
2021 Mach-E Premium
EHS consultant
flapjake314
NYC
Mach-E Select AWD
Cool. Which DashCam to you use with it? Is it strictly front or front/rear? Thanks.
that one is front only
fyi i did it myself (i have no car experience) front+rear and just routed the rear cable along the ground, used black electrical tape, pretty hidden and didn't haven't to take off the overhead or any trim that way
MnSparty38
Twin Cities, Minnesota
2022 Mach E Premium AWD Ext
Following, should have looked more with Black Friday/Cyber Monday.
22 Premium. Which front/rear camera today is recommended for:
  • isolating wiring
  • Prefer not having batteries due to summer heat
  • Easy to use for family to auto start without using apps in phones, but would rather not have to remove sd cards to view.
AliRafiee
Ali
Seattle WA
2022 Mach E GT - Grabber Blue
Software Eng.
CraigS
Craig
NZ
2023.75 RWD
Software Developer
Yes. It’s easy. Buy one of these.
https://a.co/d/d2zA9Wg
It plugs into the mirror power and gives you the USB port to plug your dashcam into.
That’s genius. I hadn’t even considered there was power available up there. Unless we can hook into the parking cameras this is the best solution
jtmyrand
Gerald
Grosse Ile, MI
2023 Mustang Mach-E GTPE, 2023 F-250 Super Duty
IT Consultant
I purchased one of these adapters and it doesn't work. The adapter is a 5 pin but the car is 6 pin. How did you get yours to work?
