DCFC Pre-Conditioning Questions
Evan
Evan
2021 Mach E Premium (Extended Range)
Hello everyone! Tomorrow I’ll be testing out ford’s “somewhat known” DCFC preconditioning feature in 20 degree wisconsin weather. I’m planning to make a video about what happens. I have a question:
If I remember correctly, you must select the charger via in car navigation. But how long should the drive be to the charger for optimal heating opportunity.
AKgrampy
Fairbanks, Alaska
There is a thread on it but I believe it was 16 miles.
Shayne
Northern Ontario Canada
2021 MME4x Prem
For reference I was sitting in it checking the 12V the other day -2C and when I shut off the hvac the the HVB inlet temp went from low teens to 32C +/- . Want to heat up the pack shutting hvac off may help. Crack a window and put on a torque ;). At -2C sunny that is not problem here. HVAC off when charging would help also.
No video needed. Turns on at 30km, 18.67 miles. Heats faster if you turn off cabin heat.
Evan
Evan
Thanks for the info! I haven’t seen any YouTube videos on this, so I’ll still make the video and hopefully someone who doesn’t know about this can benefit.
