Benjamin Kegele
- Benjamin
- Mar 7, 2021
- Northern California
- MME 21, VW Atlas, Harley Davidson Heritage Softail
some of you remember that I had a charger issue to refresh the memory: Ford supplied charger acting up - what to do | MachEforum - Ford Mustang Mach-E Forum, News, Owners, Discussions )
I had posted this issue and @Ford Motor Company reached out to me which I thought is pretty awesome. They opened a case and the lady on the phone told me that this is a known issue with their chargers, and I should schedule a dealer visit.
I was travelling for a part of June, so I let it slide a bit. End of June I finally called the dealer and scheduled a visit to check:
-home charger
and as I already scheduled an appointment, I said why not let them check the
-steering wheel heater,
as this would turn off after 10 minutes' drive when in use (even though it is not winter now)
They friendly apologized and said that the next available appointment would be July 19th and that they had some major delay going on, because of a system change.
I accepted it, as I was not really in a rush.
Over the time some other issues came up and I called on Saturday the 16th to ask if I could get those items added. I was not able to get ahold of anybody in the service department, even though from my experience they are open on Saturdays (maybe their schedule changed),
Monday 18th someone called me back and left me a message, that I should call back. After 6 or 7 tries I finally got a hold of a person, which then told me that there was no appointment for me on the 19th.
I accepted it and asked friendly, if we could schedule a new appointment which was scheduled for today the 26th. I mentioned all my issues at that time, and she said that, probably the car will need to be in half a day to get checked and then parts ordered and then need to come back. No loaner or rental available for initial inspection, but shuttle for 10 mile radius. I accepted it and went forward with the booking.
This early morning, I showed up for my appointment:
I mentioned them following issues,
-charger turns amber after a while, keeps charging but very slow, electrician verified my outlet that it was good
-I have every now and then a "12 Volt battery fault- service soon" message, came sometimes to fordpass, but mostly not and is only very short on the screen and mostly when I have not used the charger for 24hrs or so
-steering wheel heater mal function, after about 10 miles it turns off and does not heat anymore
-brakes are shuddering when abrupt or harsh braking, whole steering wheel shakes, they do that for a few months already, and I hit them every now and then hard to get the rust off (I drive 1pd mode)
-cracks on all four door trims above the button
-wireless charger is heating up my android and my apple phone, and is interrupting all the time
around 4 o'clock I got a call from the service advisor which gave me following answer to each issue
-they cannot find an issue with the charger, I should video record it as evidence (when I got back to the car the 120V was plugged in, which I had tugged under the trunk floor, not sure if they even tried 230
-there is no 12Volt error in the message stack, no stack no fault, no warranty
-steering wheel heater, was fixed with a recall she said
-brakes shuddering comes from collision control (why no collision control message)
-new trims will be ordered
-wireless charger will be ordered
she said she will leave the workorder open as parts were on order
around 5:45 I picked up my car and looked at the report, I believe though that this is not the final report as she said it is still open...
She was not there during pick up, I received it from the cashier.
it said
A: Customer States His Charger is taking Long to charge, customer states its has an orange light, custome states he had electrician come to his house and varified that it was the charger. Customer staes he then called ford and they told him th bring his charger here. Check advise Electrical
B Perform Recal -22S41- Reprogram SOBDM and BECM
C Customer States He get a Batter Fault Light on Dash. Customer States it says to contact service for 12 Volt Battery. Check and Advise Electrical
D Customer States Wireles Charging Pad Makes Phone really Hot. Check and Advise. Electrical
Here my comments about it
A according to the phone call I had with Ford, there is a known issue, why do I have to show evidence. what means check and advise?
B Why do I get a recall programmed? I have it already programmed see here: OTA update 22S41 & 22S29 & more | Mustang Mach E - YouTube do I have now two? or was the ota installed and now it is removed? How do I know if I am good or bad now?
C, D, I still do not really know what's next here
Why was steering wheel and the cracks not mentioned?
I will need to call back in the morning when tech advisor is back. She was not at the cashier when I came to get the car. It seems like the report is not complete. I just think every dealer visit I get more confused and go home with more problems as when I went there.
Dealer Visits are fun, or not?
-home charger
